if the motherboard will fit is the queston
OK, my (desktop) Gateway pc is very large for my truck. I want to remove all the components out of it and put them in a smaller case. Problem is: I don't know what kind of case to shop for. Can you assist me with what I should be looking for? ATX, Mini ATX, I don't have a clue.
Here my gateway specifications:
Chip set Intel 815EP chip set, which includes the following:
• GMCH
• ICH2
• FWH
BIOS AMI
Memory 2 PC 133 SDRAM DIMMs - 512 MB maximum
Processor Socket 370-pin ZIF socket
Supports processors with 66 MHz, 100 MHz, and 133 MHz Front Side Bus (FSB)
Graphics Intel 815EP chip set graphics controller
Audio Analog Devices AD 1885 AC '97 on-board codec
Network controller Integrated Intel Kinnereth 10/100 LAN controller
IDE interface Ultra DMA/100 (dual channel)
PCI slots Two 32-bit 33 MHz bus-mastering PCI slots
One 32-bit 33MHz PCI non-bus-mastering slot
Form factor Flex ATX
I/O panel 2 PS/2 ports, VGA port, parallel port, serial port, four USB ports, RJ-45 LAN connector, Microphone in, Audio line in, Audio line out
Design Specifications PCI 2.2
PCI Power Management 1.1
ACPI 2.0
APM 1.2
DMI 2.0
AC '97 version 2.1
Wired for Management 2.0
PC 99 compliant
Wake-up events PS/2, USB port in ACPI and APM modes, power button
Power Management Energy Star/Blue Angel compliant under Windows 98 SE, Windows Me, and Windows 2000
Management application LANDesk Client Manager
Management features • Internal ambient temperature sensing
• Power supply voltage monitoring
• Remote thermal diode sensing for direct processor temperature monitoring
• Fan tachometer inputs
• Chassis intrusion detection
• Wake on LAN
• PCI card wake-up event
• Preboot execution code
Case Specifications
Part number 3500996,3501260,3501284
Case Specifications:
St. Louis Micro ATX Tower Case Specifications
Manufacturer Axxion
Dimensions (H × W × D) 15.0 × 7.0-inch × 15.0 inches without bezel
15.0 × 7.0-inch × 16.0 inches with bezel
Form Factor Mid-tower
External Bays 1-dedicated 5.25-inch CD/DVD drive
1-dedicated 3.5-inch floppy disk drive
Expansion Bays One external 5.25-inch bay
2 internal 1-inch hard drive bays
Other Features Card access cover accesses external expansion slots
Power button
Service door removes with two release levers
200 watt (W) or 250 W power supply
AtmosUSA.biz, E-Cig Mods
"A great smoking alternative"
Make a Case from MDF yourself, a bit of time and a few quid will see you right, im making one for my P4 System that im uupgrading to, :-) Use 12mm MDF,
P4 Celeron 2.2 - 512MB - OPUS 250 - Audigy SE - BU353 - HQCT - No Speakers though :-(
Thats True, or maybe i hit submit two years ago :-)
Thanks though, obviously this thread is slow to have new posts.
LOL, well since the thread is revived I may as well add to that he should build his own case.
-------I'm hungry
