Results 1 to 10 of 11
Thread: Internal USB Hub?
    Jul 2004
    NH
    Internal USB Hub?
    Do they make an Internal USB hub? i will need a hub for my USB items but i dont want to buy a normal one for two reasons
    1) im going to crack the case open anyways, going to mount it to a panel in the car to make it look clean
    2) i dont want to have to splice the power for it. would like to just use one of the power supply hookups (HHD/CD power plug)
    any suggestions?
    I dont really have the ability to make one, my electronics skills are weak..
    Sep 2003
    Elgin, IL
    huh? why would u need an internal hub? if you have a m10000, you have 2 on the back and 2 more on the header. most other motherboards have extra usb's on the hedaer too.
    1) fine....then mount the usb hub on the same panel too.
    2) so get an unpowered usb hub.
    Mar 2004
    Vancouver, BC, Canada
    You can buy a PCI card with more USB ports.
    Raw Wave Defiler's Avatar
    Jan 2002
    Temple Terrace, Fl.
    Do you mean one that stays inside the computer case? If yes, then you could take a small USB hub and tap into the 5V molex connector and power it that way.
    Aura MR62 (F and R)
    My Current MP3s
    IamDefiler.com
    Jul 2002
    Boston, MA
    They also have the 3.5" drive bay hubs.
    You could simply remove it and put it internally as well.
    -Mario
    Jul 2004
    NH
    im going with the nano board when it comes out.. so 2 on the back and 4 on board.. it will all be built in to the glove box (space limitations, no case, custom cover)
    It will have a CF reader and a smart card reader.. there goes 2 of the 6 USB ports.. sort of a waste for just readers..
    there will be a lot more USB stuff.. GPS, ECU hookup, multiple cams (might use a home security connector CCTV?) FM receiver.. radar detector.. and i was going to mount a few (at least 1) to the front panel for connections (USB key chain or such)
    it doesnt HAVE to be powered, but i was going to use the hub for the ones for the front panel stuff which depending on whats plugged in to it MIGHT need power.. so... power it now, no problems later..
    the 3.5 drive bay sounds like just what im looking for, thanks.
    Maximum Bitrate d_sellers1's Avatar
    Mar 2002
    Austin, Texas
    Quote Originally Posted by jrich523
    Alot of the internal 3.5" drive bays have a USB header. This is what will be used to connect the drive to the USB on the board.
    Derek
    Progress [||-------]
    View my Worklog to see some of my progress.
    Downgraded Progress - Starting with another car... 09/13/06
    Jul 2002
    Boston, MA
    Quote Originally Posted by d_sellers1
    Derek
    True, he just needs to make sure he orders a hub version...
    These look like you connect 1 or two in and get 4 out.
    http://www.everythingusb.com/hardware/USB_Hubs/
    Inquire and see...
    -Mario
    Jul 2004
    NH
    http://www.everythingusb.com/hardwar...rt_Bay_Hub.htm
    only its self powered...
    I know when i used a USB hub before i ran in to power issues with a cam and a few other things on it.
    I guess i could use this for the CF/smart media reader and for the free port on the interface..
    great.. thanks guys..
    Mac Car Moderator kandyman676's Avatar
    Maryland
    i knows you have space problems, but a PCI USB card will be much more simple and is already self powered..
    "If it works this good why F with it?" -KMFDM "Intro"
    Strive for ethical wardriving: http://faq.wardrive.net/
    My CarCPUs: v1 - 2000 | v2 - 2004
    Mp3Car Meets: http://detrimental.org/eyecandy/MP3CarMeets
  1. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  2. Will this layout with a remote USB hub work?
    By NoPistonPC in forum General Hardware Discussion
    Last Post: 08-21-2005, 04:24 PM
  3. Power for usb hub
    By bklynkaos in forum General Hardware Discussion
    Last Post: 01-24-2004, 06:45 PM
  4. wireless usb kb + mouse + hub idea
    By crippy in forum Input Devices
    Last Post: 10-12-2003, 07:06 PM
  5. USB Sound and Bus powered hub
    By Suprapc in forum General Hardware Discussion
    Last Post: 04-21-2003, 04:21 PM
