Thats not RGB. It is VGA. the cable is seperated into Red, Green, Blue, H&V sync BNC connectors. Same video format just a diffrent connector cable.
Monger
ICQ-7207702
I found this on the web. http://www.cablewholesale.com/image/10h1-18106.jpg
Would VGA look good on a screeen that took RGB inputs?
The price is only $12
Monger
ICQ-7207702
Monger
ICQ-7207702
UPDATE: I moved farther north. Now its even too cold for the deer; only moose now
What kind of monitor do you intend to use it with?
I use those cables constantly at work. We call them fanouts. All they do is break out the HD15 connector to the more robust BNC connector. They do not make any changes to the signal itself. It definitely depends on your monitor whether or not you'd need to use this cable.
KG6OQD
www.americansandassociation.org
