Results 11 to 20 of 23
Thread: USB 2.0 3.5" hard drive adapter - WOW!
  1. #11
    Maximum Bitrate eCarô's Avatar
    May 2003
    SE Michigan
    USB2 is not faster than IDE, but it's pretty quick. Here is a report from Sandra on one of my HDs (a Hitachi Deskstar (IBM) 120GB 7200rpm 8MB cache).
    The red is my drive. Below it is what Sandra thinks a similar drive should do on ATA100. Below that is what Sandra thinks a similar drive should be running, if connected by USB2 (I'm not sure why I beat their estimated by a fair amount). Then you have USB1.1. And I threw in a SCSI for kicks.
    Also when I hooked the same drive to the same computer via IDE, I got around 33,000kB/s (just a little more than Sandra estimates).
  2. #12
    Maximum Bitrate d_sellers1's Avatar
    Mar 2002
    Austin, Texas
    Again, was thinking the same thing as eCar but forgot to put that in my post a few minutes ago. eCar strikes again.
    Derek
    Progress [||-------]
    View my Worklog to see some of my progress.
    Downgraded Progress - Starting with another car... 09/13/06
  3. #13
    May 2003
    SE Michigan
    Quote Originally Posted by d_sellers1
    Derek
  4. #14
    Dec 2003
    how do you power it in the car. do you just use the adpater to transfer the stuff, or as a whole, and use it in the car. since an invertor, woudl generate noise, and you would pick it up in the car
  5. #15
    Maximum Bitrate eugenen's Avatar
    May 2002
    Ohio
    I always thought about buying 3 or 4 USB-IDE adapters and make an external RAID for my laptop. In the US we can buy these for $20 so 3-4 isn't that bad.
  6. #16
    Maximum Bitrate Yuriy's Avatar
    Jun 2004
    Seattle
    Quote Originally Posted by faiz_23
    I use an inverter. There is a little background noise, but you can't even notice it when the music is playing. The external drive is powered by an adapter connected to the inverter.
    00 Saturn SL2, boosted @ 8 psi - CarDomain
    Newest install - my quickest ever
    My 2nd carputer - b4 I broke the touchscreen
    My very first carputer - voted the most ghetto
  7. #17
    Constant Bitrate Aftaab001's Avatar
    Mar 2004
    Kent, UK
    It's an AC to DC transformer......u get 5volts and the 12volt which is a normal molex adapter e.g red, black, black yellow (5v, gnd, gnd,12v)
    it's 5 volt that goes to the IDE connector and i jumped the molex connector from my opus...................... simple
  8. #18
    Aug 2003
    Quote Originally Posted by Aftaab001
    Ditto, my USB hub is powered off of my 5v rail (HDD rail) from my motherboard's PSU. It's nice because it turns it on/off with my PC.
    Many components like this only require 5v..
  9. #19
    Aug 2003
    Here's the one that I want. $35 with free FedEx shipping.
    LINK
    When it says "self-powered" mode, does this mean it gets power off of the USB port and won't require the separate power plug? When WOULD you need to run separate power?
  10. #20
    Mar 2002
    Austin, Texas
    Quote Originally Posted by sq_geek
    Most of the time with USB stuff, this means that the device will draw power from the port. Not sure how this will come in to play with a drive. I know 3.5" drives need +5V & +12V. I'm planning on having to run a power line. If it will power the drive by itself that would be great but I can't give you a positive answer at the moment.
    Derek
  1. Help!!! laptop hard drive
    By ashbosh in forum General Hardware Discussion
    Last Post: 07-15-2005, 01:34 PM
  2. Laptop Hard Drive in carputer...
    By Powers in forum Newbie
    Last Post: 05-08-2004, 10:37 PM
  3. Laptop Hard Drive Problems
    By Powers in forum General Hardware Discussion
    Last Post: 04-28-2004, 07:21 PM
  4. hard drive probelms with sub woofer?
    By gaZooGA in forum Newbie
    Last Post: 10-25-2003, 10:03 PM
  5. External USB drive
    By mtmsol in forum General Hardware Discussion
    Last Post: 11-27-2001, 05:25 AM
