Results 1 to 7 of 7
Thread: Dumb terminal
    Jul 1999
    Greensboro NC
    Question Dumb terminal
    Im looking for any ideas (good, bad, or just plain stupid) of how to use my Compaq LTE/286 laptop as an interface to my MP3Car box. The Laptop is a 286 12MHz with one parrallel port one serial port one 1.44 meg floppy drive NO hard drive and a very nice grayscale type Backlit LCD. Any help would be appreciated thanks.
    Catlas
    P.S. This is NOT a post about 'How can i use the display from my old laptop on my MP3box' I want to use the whole machine or as many parts as neccsasary.
    Aug 1999
    IL
    Thumbs up
    There are a couple plug-ins on the winamp site under the general section that may work. I know there is a telnet server plugin for controlling winamp with a telnet client, and also a few other ones that may work!
    Oct 1999
    Yukon, ok , USA
    Lightbulb
    You might try using a terminal program. something like procomm plus, etc. There are several of these out there for dos. Other than that you might be able to write your own interface throught the serial port.
    Being a 286 your options are limited, but I think if you run some sort of terminal emulator, that should work. Now some of this does depend on what os your mp3 box is running. LInux will be easy. Dos/WIN9x is a different story.
    Jul 1999
    Greensboro NC
    Unhappy
    One of the main constraints of the box is the fact that it has no ethernet card and i have not been able to find one for it. and even if i did i would have to give up my 1 meg memory expansion board to use it(leaving me with only 640k).
    thanks for the replies tho
    Catlas
    Oct 1999
    Yukon, ok , USA
    Exclamation
    Who said that you had to use ethernet. what is wrong with serial.
    Jul 1999
    Greensboro NC
    Unhappy
    Oh theres nothing wrong with serial...thats one of the main options I was looking at. i assumed Procomm plus was for eethernet...was i wrong about that?
    Dec 1999
    renton, wa, usa
    Cool
    procomm plus is a terminal program.
    I'd recommend commo, it's a much tighter and better written terminal program.
    ftp://ftp.nfbnet.org/bbsfiles/comm/COMMO70.ZIP
    What mp3 player are you using? I haven't come accross a decent serial terminal control plug in for winamp, and unfortunately mpxplay doesn't work with a redirected command prompt.
