Worth looking into, to say the least!!!
Thanks!![]()
Ok guys... I wasnt aware of this so I assume others are not either, at least someone else on here doesnt know it. At any rate, Ive been messing around with my brand new motherboard I got in over the weekend. At different times while fooling around with it, I noticed I had the POST going in as little as like 5 seconds. This is a brand new hard drive so I was impressed but at the same time I almost expected it.
Well, after fooling around with it a bit more, putting my MP3Car hard drive in my home system and adding new songs to it, I then put my car hard drive back into my car system and "wtf, it takes POST 25 seconds". The bad part was that it still only took the normal time to do the actual tests of POST, but then after that it would say "Wait..." and just sit there for 15-20 seconds. I fooled around with every BIOS setting that it possibly could be and to no avail, it still took 25 seconds
Then I remembered about the only thing that had changed was that I had put my hard drive in my home system PC. I checked out the jumper settings on the hard drive and saw that when I pulled it back to put in car PC, I set the jumper as master. So I just simply jumpered it so that it was set as a "single" drive and booted back up again. Well, to my surprise, again it was back at a 5 second POST. I tested, retested and tested some more and that was the only thing that effected it to drag it out.
I assume that basically even though its a Master drive, and the BIOS is told to not look for other drives, it still looks for a slave if it has a master. Basically just thought Id share this with everyone. I know back in my 1.0 system I was always trying to speed up the POST after it ran all the tests. Now, even on my old mobo I bet that this would help it dramatically as well. In any regard, I hope someones this and is helped by it.
The Grand aMP3 Project
Car: 96 Pontiac Grand Am
Current Setup: AMD K62 300MHz, 64MB DIMM RAM, 20GB WD Hard Drive, Basic Video & Sound
Thanks!![]()
sounds interesting.....
one question, how do you set your hard drive to single drive? all the ones i have ever seen have 3 jumper settings, Master (M), Slave (S), and Cable Select (CS)?
do you just mean cable select, or no jumpers at all??
I took it to mean Master instead of Cable Select.
I just found this:
http://seagate.com/support/kb/disc/r..._settings.html
If your BIOS allows it, I'd suggest just setting the HDD parameters by hand. No more boot-up searching for EIDE devices is often a major speed improvement. If your BIOS supports it, "Fast POST" or "Quick POST" helps a lot, too. Turning off autodetection on the floppy seems to make things go a smidge quicker as well.
Right now my CarPC goes from power-switch to media app (including network initilization) in 17 seconds flat.![]()
2003 Toyota Camry V6
Kenwood Excelon 790 HU, VIA C7 + M2-ATX, Xenarc 700TSV, and 5 discreetly installed amps.
Blah! 17 seconds is nothing!
I got 17 minutes!
oh wait..
00 Saturn SL2, boosted @ 8 psi - CarDomain
Newest install - my quickest ever
My 2nd carputer - b4 I broke the touchscreen
My very first carputer - voted the most ghetto
At least you have it booting, mine is still in pieces. I am working with days not minutesOriginally Posted by Yuriy
I do belive that the first boot is usually the hardest, though!
[COLOR=Navy][SIZE=1][FONT=Comic Sans MS]Tektility
be strong!!! don't let it get to you!
Originally Posted by dominic
Not all brands have the 'single' option
Wth CS jumped, most motherboardslook,for a while,for a second drive. If the drive has pins to be jumped for SINGLE, then MASTER will also look for a second drive. On my desktop it's about a 10 second difference.
I find this to make a HUGE difference. Becasue (as said) the BIOS won't look for a hard drive, it'll just assume it has what you tell it it as. A word of caution though. Manual seting of HD parameters must be done correctly, you won't damage anything but you can get some funny results... like data writting over data. And DON'T FORGET you set it like this when you're scratching you're head for hours after you put in a second or a new HDD.I'd suggest just setting the HDD parameters by hand
I added a second hardrive to a friends Dell and it took me about an hour to realize it. When I AUTO detect the HDD the BIOS displays info just like it was entered by hand, so I overlooked it about 37 times.![]()
