Results 1 to 9 of 9
Thread: epia m1000 nehmiah + laptop HD problems
    May 2004
    so yea, i have a new m1000 and a new hitachi 40gb 5400 laptop HD,
    it wont detect the stupid HD, im using an adapter btw.
    --i knw d HD works coz if i use USB it works. cud it be the adapter = ****ed?
    --i also know that mobo ide is ok, coz i tried regular desktop HD = OK!
    also, i thought u can install windows to a USB HD, i got it to detectd my usb HD couple times during winxp install, but now it cant detect it.
    i hate this crap!!@&$)!*&$)
    May 2004
    Check your jumper on the hard drive.
    Variable Bitrate euro320i's Avatar
    Apr 2003
    Near Frankfurt
    Do you have power to the HD? Just checking......
    o/______\o
    (oo_OO_oo)
    []o-----------o[]
    '94 320i
    May 2004
    yea. i dont have any jumpers on the HD, hence it is on disk0 mode = master mode which was how i got it.
    its on my secondary master IDE, dvdrom is on primary master IDE.
    and yes i have power since the adapter has a 4 pin HD power supply jack u can plug into
    edit: and you can feel the HD doin something.
    May 2004
    bump
    May 2004
    Try the primary cable then.
    I don't think I have ever seen a hard drive without jumpers.
    Apr 2003
    Near Frankfurt
    try unplugging the DVD and see if the system sees the drive. If so, then your lappy HD is set to cable select. Just the lappy HD on the IDE bus should show it if not, then the HD in "in the eimer"..
    o/______\o
    (oo_OO_oo)
    []o-----------o[]
    '94 320i
    May 2004
    yea. well, to start. . the HD works.
    when i just plug in the HD, still nothing. put in the jumpers, still nothing. hehe
    put it as master setting on master cable, nothing
    put is as slave setting on slave cable + desktop hd as master on master cable = desktop HD name being fu**ed in bios, and then won't detect.
    also, i tried this on my desktop,, same results.
    Apr 2003
    Near Frankfurt
    Well sorry chicochu sounds like your lappy hd is fubar!! I don't know what that means but it sounds bad enough... did it detect as a solo drive on a single ide ribbon?
    o/______\o
    (oo_OO_oo)
    []o-----------o[]
    '94 320i
  1. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  2. Anyone have problems with a Sproggy and Epia M1000?
    By surfer6262 in forum Power Supplies
    Last Post: 07-04-2004, 04:28 AM
  3. Need help with External USB Laptop HD
    By VWTronics in forum General Hardware Discussion
    Last Post: 05-26-2004, 01:58 PM
  4. Laptop Hard Drive Problems
    By Powers in forum General Hardware Discussion
    Last Post: 04-28-2004, 08:21 PM
  5. DC-DC Converter for C134 EPIA M1000 Nehmiah
    By entr0py in forum Power Supplies
    Last Post: 02-24-2004, 09:22 PM
