CPU QUESTION ?
Does the Duron processor run to hot to be used in the car. I know the Athlon draws alot of power but I was not sure about the duron. How cool do the celerons run ?
Thanks for the help.
Duron should be good for the car. People only put big-*** heatsinks on them because they are easy to overclock.
Running at the default voltage/clock with a normal HSF will be fine.
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
