Results 11 to 20 of 22
Thread: Laptop screen controllers
  1. #11
    Mar 2001
    Post
    dan,
    which screen is it? you might be able to download the specs
    and that might have the connector type.
    -paul
  2. #12
    Mar 2001
    Post
    well i was checking out the ATI card and it has a 20pin
    DFP connector:
    http://www.ati.com/na/pages/products...lcd/index.html
    unfortunately for me i have the Sharp 8.4" and i think i need
    a 32pin DFP. also even if your screen has a 20pin DFP you
    will probably want to verity that the pins out of the card
    match the pin-ins into the LCD. I'll email ATI and see if i can get the LCD pinouts.
  3. #13
    Maximum Bitrate gizmomkr's Avatar
    Dec 2000
    Smyrna, Ga, USA
    Post
    I have heard the dfp connectors are some kind of standard, but the stuff on the LCD is specific to the lcd.
    www.flat-panel.com has been really helpfull in finding the right cables to connect my lcd stuff. they are kinda pricey though.
    Dont forget, you still need an inverter for the backlight - that part does not come with the ati or matrox card..... its around 30 bucks from flat-panel.
    Gizmo-
    Techonlogy on Wheels
    http://www.hjnetworks.com/car
  4. #14
    Mar 2001
    Regina, SK. Canada
    Post
    The screen is a NEC NL8060BC31-05. It came with the inverter already, or I think that's what it is. It's some little PCB that the seller called a "Backlight power module" or something. I should stick it in my scanner and post a pic...
    AMD Duron 750, 128m RAM, 10gig WD, 12.1" TFT screen, SB Live! 5.1, custom plexiglass case
    TalonTemple.com
    TalonTemple.com
  5. #15
    Mar 2001
    Regina, SK. Canada
    Post
    Here's what the attached board looks like.
    Anyone know what it is? On the left is a beige connector that goes into the LCD and the right is the same type of connector, but with way more pins in it.
    TalonTemple.com
    TalonTemple.com
  6. #16
    Dec 2000
    Smyrna, Ga, USA
    Post
    Yup, Its an inverter - double check the schematics when you fnd em.... but going by the photo -
    The left side is High voltage out,It should attach to a connector on the lcd that goes to the backlight.
    The right side is low voltage in. This should go to a 12v DC source.
    Gizmo-
  7. #17
    Mar 2001
    Regina, SK. Canada
    Post
    Sweet. Well that saves me $30. Still can't find any leads on a LCD controller though. What kind of controllers are you guys running? (for the ones with laptop screens)
    TalonTemple.com
    TalonTemple.com
  8. #18
    Maximum Bitrate albysure's Avatar
    Dec 2000
    pittsfield, ma.
    Lightbulb
    yup...thats what it is. it has high voltage going to the screen
    AMD K6-3 450, 15GB HD, 256M Ram
    DVD, 10.4" touchscreen, 2-5' lcd's, ati all in wonder 16mb, Alpine, MB Quart, JL, Audio Control
  9. #19
    Maximum Bitrate Raas's Avatar
    Jan 2001
    The Netherlands
    Post
    I have a sharp torisan display,
    And i believe i got a 40 pin connector to it.
    Still wondering if it's tft or the slow one... think the slow one.... damn....
    DVD would look like crap wouldn't ?
    Greetz
    Mark Raassens
    Horst
    The Netherlands
    mark.raassens@12move.nl
    Raas - The Netherlands
    ME: VIA epia m10000, lilliput 7', opus 150w, 80gb<br>
    GF: IBM Thinkpad 380, ext. 3.5 80gb, 40x4, PB-IR
  10. #20
    Maximum Bitrate Meatballman's Avatar
    Jul 1999
    Hartsville, SC
    Post
    Yes...I have a torisan DSTN display too. The refresh rate is too slow to do DVD very well, so I didn't bother getting a controller for it.
