Results 1 to 10 of 11
Thread: Wiring/GPS problem
    Constant Bitrate Needstorage's Avatar
    May 2004
    Belgium
    Wiring/GPS problem
    I've got a wiring problem. I'm unable to get a wire (USB-GPS receiver) running from the engine compartiment to the dashboard. (I have Ford Galaxy and it has a big dashboard. Everything is very tightly...
    I can't use the GPS-mouse on my dashboard because it has this "thing" in the glass for anti-condensating purposes.
    Is there a way to connect a USB device to a Bluetooth enabled device? What I mean is a sort of convertor that has a USB port on it where you could put a USB printer, USB Card reader, or indeed a USB GPS mouse and transmits to the computer using bluetooth?
    I don't really want to buy a new gps mouse because I have a perfectly good working one.
    I thaught of smashing my front window but my wife wasn't in for that idea... lol
    Maybe an other idea is to re-use the OEM-GPS receiver/antenna that's built in?
    Needstorage
    Who the hell is general failure?!?
    And what the f@#k is he doing reading my drive C:\?
    FLAC IntellaWorks's Avatar
    Jun 2004
    NH
    Engine compartment, does this mean the GPS unit will be mounted on the hood of your car ?
    GPS signlas are like light from a flashlight (you probably already know this) so the GPS unit must be outside on the car. When you say engine compartment it means to me that the GPS unit is in fact somewhere on the front of the car. BUT because the roof of your car is metal and higher then the hood you are reducing the angle at which it can recieve signals.
    You should try to put the reciever on the roof (or highest point of the car) This will get rid of the problem of trying to go through your firewall. instead you can go through the door Jam or something like that.
    May 2004
    Belgium
    Quote Originally Posted by IntellaWorks
    what does door jam mean? (I know what a door is, so don't be to hard on me )
    I tried a temporary install where I placed te GPS mouse where I wanted it to be and reception was fine. (It's located under the hood, but very near to the side and the window. There's this small band that just is made out of plastic, and it is big enough to hold the GPS mouse underneat. It even has the advantage of being installed perfectly invisible in this case.)
    Also the nose of the car is not very vertically. Do you know what I mean... err... like in this nose:
    Needstorage
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    If there is a 'factory gps antenna' in the car, perhaps you can mount yours right next to it?
    FLAC muldrick's Avatar
    Jun 2004
    South-Central PA
    Quote Originally Posted by Needstorage
    A door jamb is what the door closes into, were the (reciever) latch is, the "b" pillar, the piece between the front and rear doors.
    AtmosUSA.biz, E-Cig Mods
    "A great smoking alternative"
    May 2004
    Belgium
    Quote Originally Posted by muldrick
    Ok, get it now. I'll take a look at it.
    Needstorage
    Jun 2004
    NH
    Need storage, I definatly would NOT keep it under the hood. I'm afriad of the heat plus, there is heat shielding AND the hood above your gps unit. I know you said you've tested it but here is some food for thought.
    I can get a partial lock when my gps reciever is at my developing PC. I only know its a partial lock because I'm writing software that reads NMEA 1.83 (or the data comming from the GPS unit) when in my developing station, it only gets a partial data (meaning ther is certian peices of data missing) i.e. (speed, direction) because the signal is not fully being read. It's enough information for GPS software to give a location (sometimes) but not all the time (depending on what part of the signal was missing)
    Simply put: Your GPS wont be as accurate, and if your using a "Standard" gps which already is 25ft innacurate then that not that great.
    if you have a van, then its perfect for gps, throw it on the roof in the rear of the van. Thats where they usually install XM satellite recievers.
    Jun 2004
    NH
    addition
    My developing PC is under a roof. (thats why I used that example)
    May 2004
    Belgium
    Well, my factory built-in GPS receiver is on top of the roof, at the back. If i'm able to put my GPS mouse over there, I have another question. How long can I make this USb cable to the GPS-receiver. (in meters, please)
    Needstorage
    Maximum Bitrate d_sellers1's Avatar
    Mar 2002
    Austin, Texas
    It looks like the standard is about 16ft/4.8m. I did find this cable. It is 16ft/4.8m and it has a repeater built in to it. In theory, you could have this and then another 16ft/4.8m cable. Think about 30ft/9.1m should do you pretty good.
    Derek
    Progress [||-------]
    View my Worklog to see some of my progress.
    Downgraded Progress - Starting with another car... 09/13/06
  1. Hard audio quality problem: Noise / Ground loop?
    By Burat in forum General Hardware Discussion
    Last Post: 09-09-2004, 07:08 AM
  2. Lilliput Powering On/Off problem
    By masch in forum LCD/Display
    Last Post: 05-09-2004, 12:55 PM
  3. power on problem ??? help please anyone
    By Pingo1969 in forum Power Supplies
    Last Post: 04-07-2004, 08:47 AM
  4. I can't connect my hard drives + fan problem
    By haisook in forum General Hardware Discussion
    Last Post: 02-03-2004, 10:42 PM
  5. Annoying problem
    By c-dawg in forum General Hardware Discussion
    Last Post: 07-22-2002, 09:19 PM
