Results 1 to 10 of 15
Thread: Inverters...
    Sep 2000
    Redmond, WA
    Question Inverters...
    I was just curious, are there any problems / cons with using a 12voltDC to 110vAC Inverter and a standard ATX power supply as opposed to a DC-DC power supply? For one, it would be about 1/3 the cost for twice the wattage...
    Retired Admin Aaron Cake's Avatar
    Jan 2000
    London, Ontario, Canada
    Cool
    Problems:
    -noise
    -inefficiency
    -size
    -heat
    Advantages:
    -lower cost
    DC-DC is the way to go.
    Aaron Cake
    Player: Cyrix 200, 32MB RAM, 10.2Gig Quantum HD, Onboard EtherNet/Sound/Video, Custom Lexan Case, Arise DC-DC, Win95 Kernal w/Custom Player
    Car: '86 Mazda RX-7 w/Basic Performance Upgrades
    Jul 2000
    Louisiana
    Post
    I dont think the heat size and inefficiency would be a problem for me.
    they aren't too big to fit under a car seat. They wont heat up enuff to burn u (the good ones have fans) the inefficiency wont kill ur battery, and i have heard of DC-DC to have had noise too. Spend 5.00 on a heavy duty ground loop isolater and it should eliminate any noise. Also the DC-DC's u have to make, which requires time, and anyone with good knowledge about money knows that that: time=money.
    Apr 2000
    Post
    Not to mention that with an inverter when you need to work on the computer you can simply take it out and plug it into an outlet in your house.
    Jul 2000
    Louisiana
    Post
    Jan 2000
    Cool
    You don't have to make a DC-DC. Arise Computer (http://www.arisecomputer.com I think) has them for sale.
    If you want to power a DC-DC powered computer in the house, just use a 12V power supply good for about 5A. Works great. An old computer power supply will work.
    Aaron Cake
    Aug 1999
    Upper Marlboro, MD 20772
    Post
    Aaron Cake: They just don't understand stand until they get one of those arisecomputer PSU. I have 3 of them already. I can power up my box from a +12v of a regular psu. I don't see why go from DC->AC->DC... ppl think about it, does that make sense?
    looks like only me and Aaron Cake has these psu and are enjoying it.
    abcd-1
    abcd-1
    Variable Bitrate Cyberphox's Avatar
    Sep 1999
    New Glasgow, Nova Scotia, Canada
    Post
    My order is going in for one for sure
    DC-DC rocks!
    Technology, Gadgets and Making Money Online
    http://www.genemills.ca
    Nov 1999
    Sydney NSW Australia
    Post
    Lets put it this way...
    The people who know enough electronics will never go for the inverter cos of the problems Aaron Cake mentioned. And who ever works in the industry of electronics and computers will know that design (of anything at all) should be as reliable, most efficient and solve most of the problems that encountered.
    So the inverters are the easy way out for those who dont really think about the problems mentioned above. But most the people here who had the mp3 players running in their cars for few years now can tell that DC converters are the best solution in-car conditions.
    From the engineering point of view, there is no point of converting the DC to AC then converting it back to DC again... Its just NOT efficient!!
    I personally started with home made inverter more then a year ago but soon after was thinking of replacing it with DC converters, as i did.
    Belive it or not i end up saving 7Amps of current draw from my battery which also means loger battery life when the car is off.
    At the moment the DC converter uses 3amps Max power to run the whole system (which is more than 90% efficient). After changing from the inverter to DC converter it also made it possible to reduce the size of the MP3 player box from 40cmx35cmx10cm to 23cmx24cmx7cm.
    So looking at the facts its up to you to decide which way you want to go!
    Fosgate
    Fosgate
    System Comp V3 - In progress.
    Low power MB with C7 CPU, DC-DC PSU, car ECU link, USB TV, GPS, 7" TFT, Wireless, Voice.
    Sep 2000
    Question
    Inverter ppl
    are you running a 120VAC line in the same chase or whatever as any of the 12VDC wires are ran... exspecially speaker wire and its like?
