Results 1 to 10 of 12
Thread: noob question
    Jul 2004
    noob question
    not sure if i am posting in the correct forum
    i've been using caputer for a while
    but stupid enough...i didn't think i could output the sound
    to my car speakers..instead i put a set of pc speakers in there
    i m new here...now i see MP3car.com...with alot of skillful
    ppl...and most of u actually hook up the sound to the speakers in the car
    may i know how u guys do that?
    Variable Bitrate brooksware2000's Avatar
    May 2004
    Minot AFB, ND
    Many ways to do it; here are a few:
    Run output of your soundcard to an auxiliary input on your head unit if it has one. If your head unit does not have an auxiliary input you can use an RF Modulator that plays through the FM station on your radio. Also, if you have a tape deck you could run the output of your sound card to one of those cd to tape converters. Those are relatively cheap methods of doing it. More expensive methods are running the audi output through a USB sound card straight to your amp (if you have one).
    Check out my hopefully useful site...
    www.hobbybotics.com
    It's still under design but it is functional
    Variable Bitrate euro320i's Avatar
    Apr 2003
    Near Frankfurt
    A lot of guys here hook directly up from the PC output to the RCA inputs of an amplifier. It has been reported to give a "jaw-dropping" sound. Wish it dropped a couple of other things....
    o/______\o
    (oo_OO_oo)
    []o-----------o[]
    '94 320i
    Constant Bitrate saikano's Avatar
    Jul 2004
    Huntsville AL
    i have the same question...so what if i don't have a head unit [i'm replacing it with the lilliput], and i don't have an amp?
    don't let a day go by without finding some wonder in it...
    TX5
    TX5 is offline
    Sydney
    you will need either a HU or an amp
    Jul 2004
    Huntsville AL
    [cry cry] what sort of amp will i need? i have a 55amp alternator, plus i'll be running a computer...and lilliput
    Apr 2003
    Near Frankfurt
    Take a look into Ebay, there are a lot of cheap car amps for sale. If you go mega power, then you may want to get a CAP to get that extra juice when you need it.
    You'll need to get a phono to RCA connectors to connect your PC to your amp. Then use Windows Media Player or Winamp to control your volume. Good luck..
    http://www.crutchfield.com/S-u8RZ2OV...&avf=N&search=
    This looks like a good amp...
    o/______\o
    (oo_OO_oo)
    []o-----------o[]
    '94 320i
    Jul 2004
    Huntsville AL
    i just want a little amp, i'm not a sound freak...[not that i have anything against them...] i just want to hear the audio created by my comp
    my question was asking more along the lines 'what type of amp should i get?' not 'where?'
    thanks a lot though
    FLAC Pudge's Avatar
    Sep 2003
    AZ
    The reason you hear audio out of your computer is because the speakers you plug into the back of them are powered. The audio signal is uselss unless it is amplified, whether it's from a HU, ampifier, or computer speakers.
    My Carputer! (More Car Pics at the end)
    2 Kicker Comp 10"
    Epia M-9000, 256 MB DDR, 120 Gig HD
    Lilliput 7" VGA Touchscreen
    Check it out?!
    Jul 2004
    Huntsville AL
    i knew that, i was just thinking i could use the same source my head unit did
    hey euro, thanks for that link...even though that amp is a little stronger than my alternator [i believe]...i found a little wizard on the site that determines what is right for my vehicle...
    thanks!
  1. New noob question from HeyItWRX!
    By heyitwrx in forum Newbie
    Last Post: 07-12-2004, 06:22 PM
  2. Stupid NOOB question..
    By phatbimmer in forum MediaCar
    Last Post: 05-03-2004, 07:01 PM
  3. NooB question
    By ouikikazz in forum Newbie
    Last Post: 04-19-2004, 01:34 AM
  4. Noob Here with a question...
    By ImprezaRS-T in forum Power Supplies
    Last Post: 03-15-2004, 05:09 AM
  5. A nOOB question about monitors.
    By GATrooper in forum LCD/Display
    Last Post: 10-12-2003, 02:21 AM
