Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: TC10000 RAM/memory question
    Variable Bitrate Pabs's Avatar
    May 2004
    Somewhere in the UK
    Hi Guys
    1st thing, anyone got the beep codes for a tc10000? Mine gives me 1 long beep continuously.
    2ndly, i am using pc2100 256mb ddr 266 memory, as stated. But i believe this is the problem with the board.
    Anyone know about this?
    Cheers
    Constant Bitrate saikano's Avatar
    Jul 2004
    Huntsville AL
    the epia boards are all using the AWARD BIOS [if i'm not mistaken]...so you should AWARD BIOS BEEP CODES and a resource will show you the answer
    it is most likely a memory seating problem
    don't let a day go by without finding some wonder in it...
    Mar 2004
    Maryland/NOVA
    it could be RAM.
    what kind of keyboard are you using(ps2/usb)?
    2001 Acura CL traded for a 2006 Subaru Legacy GT
    7" Lilliput Touchscreen
    NANO-ITX+m1-atx
    512 DDRsodimm
    60g SATA Laptop HD
    4x Apple DVDslot
    digimoto OBDii
    mS GPS
    mini BT keyboard
    relocated HU faceplate
    FLAC Chairboy's Avatar
    Jan 2004
    My M10000 only works with non-ECC RAM.
    May 2004
    Somewhere in the UK
    Hi
    I am using a ps2 keyboard and mouse, but even with them unplugged i get this error. I am lead to believe it is a ram problem, according to the beep code of 1 long beep, pause, repeat forever......
    I bought my PC2100 256MB DDR266 ram from ebay. It has a CL of 2.5 and I am sure it is non-ecc (at least i think it is when i checked earlier.) How can i be sure of this? The supplier of the mobo (www.icp-epia.co.uk) said its a ram problem and that i should use SO-DIMM. Surely all ram that fits into the slot is SO-DIMM, or am i wrong here? It is minature laptop ram.
    If so, where is the best place to look for replacement RAM,and what exactly should i ask/look for?
    I need it cheap as I wasnt expecting to have to pay out for more ram.
    Cheers all
    Dec 2003
    Michigan
    Pabs, my EPIA M10000 EDEN is doing the same beep code. I've done some research but the code is VERY vague, i.e. "main board problem, Video problem, ram problem". I've swapped out the ram to no avail. I'm considering RMAing it to VIA. There was some talk that the bios may have lost its mind, but since I have disabled the floppy seek in the bios, I won't be able to re-flash it. Good luck. Let me know what you find.
    2006 Chevy Colorado: VIA M10000 EDEN, 1 GB RAM, 80 GB 2.5" Seagate HDD, USB Slim Slot DVD/RW, Holux GPS, MobileVU 10.4" LCD (touch not working yet), VOOMPC Case (blue), 70W DC-DC supply.
    Maximum Bitrate Seth's Avatar
    Jun 2004
    Athens Greece
    Quote Originally Posted by Jackso
    No matter what you have set in BIOS, the M/B will allways try to boot from the floppy in case a BIOS checksum (corruption) error occurs. The floppy init routines are in the non-flashable portion of the BIOS (boot block) and it should work unless the M/B sustained physical damage. Just throw in a floppy drive and you'll see the mobo try to boot from it even if you can't see anything in your screen. You should be able to flash it.
    Clover Grayscale's Avatar
    May 2004
    Arkansas
    just out of couriousity what is the filename of the rom file that an award bios will be looking for? i know ami is amiboot.rom
    CarPC install is starting to come along again...
    Jun 2004
    Athens Greece
    I believe is awardext.rom
    May 2004
    Somewhere in the UK
    Hi Guys
    I have had my tc10000 about 12hrs max. So i dont know what to do? Do i buy more ram first? I need to test the board or ram, but do not have the ability to test either.
    Please give me ideas!
    Cheers
  1. Newb question about standard psu's
    By newbiemcnewb in forum Power Supplies
    Last Post: 06-06-2004, 10:05 AM
  2. DVD drive question
    By Pokey in forum Newbie
    Last Post: 05-11-2004, 04:26 PM
  3. quick fuse question....
    By jusatry in forum General Hardware Discussion
    Last Post: 02-23-2004, 10:54 PM
  4. Replies: 5
    Last Post: 02-20-2004, 01:08 PM
  5. lcd power question
    By jrbless in forum LCD/Display
    Last Post: 04-07-2002, 12:27 PM
