Results 1 to 7 of 7
Thread: Where to get MB riser screws/spacers?
    It's not really that small...No, seriously. judoGTI's Avatar
    Feb 2004
    I need to get a hole of some riser/spacers for my VIA M10000 MB. I'm building a custom case now and I lost the original ones. Anyone know where I can get these?
    '02 GTI
    [Routis '04] [Opus 90W] [160GB Maxtor HD]
    [Lilliput 7" TS] [VIA M10000] [XMPCR]
    [512MB RAM] [Custom housing]
    [Deluo GPS Mouse] [E-MU 0404 Soundcard]
    Progress Meter: [==============|] 99.9%
    FLAC Chairboy's Avatar
    Jan 2004
    I get 'em at Frys, most computer places like CompUSA should have them too if their builder's department is well stocked.
    Raw Wave Defiler's Avatar
    Jan 2002
    Temple Terrace, Fl.
    also try a Mom and Pop computer store.
    Aura MR62 (F and R)
    My Current MP3s
    Constant Bitrate StationRocket's Avatar
    Sep 2003
    Rochester, NY
    go here and search on standoffs
    they have EVERYTHING
    Jul 2004
    If you are building a custom case, you could either:
    Use one screw and 3 nuts for each mb hole like this: Insert screw on case wall from the outside; fasten it to the case with a nut; insert another nut to some distance from the case; put the mb; fasten it to the second nut with the third nut.
    Or you could cut spacers from a plastic ball-pen and use one screw, one plastic spacer and one nut per mb hole. That's what I did in my plexiglass case.
    These solutions have an advantage in that you don't need to tap the case holes.
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    When I worked at a computer store we had so many screws and spacers we were throwing them out, if you just ask a local computer store that is not a compusa they will probably give them to you for free.
    Maximum Bitrate srcstc's Avatar
    Dec 2003
    New Jersey
    Search for standoffs on ebay cause it's cheaper.
  1. which pci riser sive for m10000?
    By [H]Bugster in forum General Hardware Discussion
    Last Post: 11-02-2004, 04:16 PM
  2. FS: MB Quart Seperates and Rear Deck Fills
    By Krystos in forum Classified Archive
    Last Post: 01-09-2004, 08:34 AM
  3. Wafer 7850...3.5" SBC mb
    By cenwesi in forum Classified Archive
    Last Post: 05-01-2002, 06:24 AM
  4. Won't power up Hard Drive and MB at same time
    By mkkbb in forum Power Supplies
    Last Post: 04-15-2002, 12:53 PM
  5. All-In-One MB for Sale w/TV out
    By 168db in forum Classified Archive
    Last Post: 04-19-2001, 05:03 PM
