Page 4 of 34 FirstFirst 1234567891011121314 ... LastLast
Results 31 to 40 of 334
Thread: USB FM/AM tuner with RDS/RBDS
  1. #31
    Maximum Bitrate GruvThang's Avatar
    Jul 2004
    Northern Virginia, USA
    Most of the things I can think of are for Frodo and the other guys (software), removable antenna is the only hardware thing I could think of at the moment.
    [COLOR=Navy][SIZE=1][FONT=Comic Sans MS]Tektility
  2. #32
    Jun 2002
    Malaysia
    how about TV tuner option?
  3. #33
    Maximum Bitrate Seth's Avatar
    Jun 2004
    Athens Greece
    I don't think so.
    1) Very complex design (goes beyond the scope of a DIY project)
    2) HUGE tuner (VHF/UHF FM/AM)
    3) Seperate designs for NTSC/PAL
    4) Expensive components
    5) It already exists (PCI card though)
  4. #34
    FLAC Spaghetti's Avatar
    Jul 2003
    Spagcave, in da UK Today's phrase: J'aime Alizee
    OK Seth, here's one for ya: how about implimenting the RDS so that it kicks in even if you're not listening to the radio...?? Like on a 'proper' radio? Obviously you'd need to be able to turn it off....
  5. #35
    Jul 2004
    Baton Rouge, LA
    count me in to buy 2 when it hits the market
  6. #36
    Jun 2004
    count me in for 1
  7. #37
    Jun 2004
    Athens Greece
    Quote Originally Posted by Spaghetti
    I don't know if I'm getting this right but you mean that a window should pop-up when Traffic Programme (TP) or Traffic Announcement (TA) data are received causing other sound sources to mute?
    I believe capturing TP/TA data is a software issue since the RDS pre-processor SAA6588 is capable of full RDS/RBDS signal decode and the data will be continuously available through the I²C / USB bridge.
    btw here is the SAA6588 datasheet :
  8. #38
    Jul 2003
    What I meant was, that the RDS announcements to still be on, even if you're not listening to the radio.
    So, you could be driving down the M1/E-whatever motorway, listening to mp3's, but you still have automatic traffic reports. Capisce! So basically, you don't have to be using the radio to have the announcements, just like in most normal DIN-sized car stereos.
  9. #39
    Jun 2004
    Athens Greece
    It goes like this (see attachment)
    So in order to receive RDS TA or TP the tuner MUST tune either to a station or in an EON network if available. It's just that the audio out of the tuner ic is muted. It is still a matter of software design. The hardware can do it.
    Attached Files Attached Files
  10. #40
    May 2004
    how will the audio be played?
    do you have to connect it through line-in on your sound card?
    or will the data be sent through usb also? (I would like that)
    anyway, perfect idea, hope you will ship to the netherlands also!
  1. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 08:35 PM
  2. RDS Tuner for USB
    By NEO in forum General Hardware Discussion
    Last Post: 07-06-2004, 07:06 AM
  3. Mediaengine with PCI winfast FM tuner, not d-link usb
    By wonderworm in forum Software & Software Development
    Last Post: 03-25-2004, 04:29 PM
  4. FM/AM tuner
    By t-juMper-311 in forum General Hardware Discussion
    Last Post: 11-14-2001, 03:17 AM
  5. USB DVD + Radio Tuner + OEM GPS
    By gguy in forum General Hardware Discussion
    Last Post: 02-13-2001, 11:43 AM
