Results 1 to 10 of 11
Thread: epia M mobo, video driver problems
    Jun 2004
    I setup an in car pc yesterday, and it loaded up fine to 640x480 with 16 colors, then i put in the 4-1 drivers to update everything, and i restart and i get no signal to the screen. Im assuming the resolution is to high or the RCA output is not activated after than update. What can i do to prevent this?
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    I had the same problem. Are you running win XP?
    Tidder
    Try RevFE
    Sep 2003
    New Mexico, USA
    What happened with mine is VGA was set as default instead of TV-out. Happened when I installed the newest 4-1 drivers. On post and boot the tv-out would work, then it would default back to VGA. What I did was go into the Display Properties, and changed the output to TV. From then on out it's always defaulted to tv-out.
    Tidder
    Try RevFE
    Jun 2004
    how did you go to properties and do that if you couldnt see the screen? Or did you do that BEFORE you installed new drivers, because i feel like that option isnt available, maybe i should run xp (which was the plan anyways) and then i can set that to default before installing new drivers.. right?
    Sep 2003
    New Mexico, USA
    The new drivers will override your defaults anyway, because it has new defaults.
    Tidder
    Try RevFE
    Sep 2003
    New Mexico, USA
    I actually had to use another computer to get it right. I use a program called RealVNC which lets you use a remote computer across the network like you're sitting right in front of it.
    Tidder
    Try RevFE
    Sep 2003
    New Mexico, USA
    What you should have did, is installed the new drivers, and before you rebooted set your tv-out as default. I think that would work.
    Tidder
    Try RevFE
    Jun 2004
    aww thats weak, im just gonna have to plug in another monitor , o well
    i was trying to avoid that but i guess the best way to do a computer pc is to set it up before the parts are all in your car
    Maximum Bitrate wizz's Avatar
    Nov 2004
    Leicestershire UK
    Quote Originally Posted by illycut
    Which M motherboard ?
    Which screen ?
    Wizz
    Car : Ford Focus Zetec 1.6
    Carpc :Lin-ITX Plus 7" touchscreen/Toad 8" roof screen
    Morex 3688 case/M2-ATX PSU/Commell V-672 P4 3.2Ghz/1024DDR2/40GB 2.5" SATA HDD/Sony DVD/CDRW
    BU303 GPS/Mercury 11b WiFi/Parking Sensors
    Colour I/R Reversing Camera
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    I had the same thing happen to me when I loaded my 4-1 drivers. It turns out the thing switches over to outputting the signal on the S-VGA adaptor. I hooked it up to my television and switched it back to CRT in BIOS, although it was pretty hard to read! Big relief when it rebooted on the LCD.
    Want to:
  1. epia MII 12000 shipping problems?
    By theheel in forum General MP3Car Discussion
    Last Post: 06-01-2004, 09:13 PM
  2. Video problems on Micro-atx boards? (no boot)
    By Phat Justice in forum General Hardware Discussion
    Last Post: 01-20-2002, 02:29 PM
  3. FV24 Video problems "wasted space on screen"
    By Mikesz in forum LCD/Display
    Last Post: 01-05-2002, 03:59 PM
  4. Video problems while building computer
    By Maveric in forum General MP3Car Discussion
    Last Post: 09-24-2001, 07:28 PM
  5. web tv video driver
    By Schnitz in forum General Hardware Discussion
    Last Post: 03-05-2001, 09:09 AM
