Results 1 to 6 of 6
Thread: moving puter to trunk, need suggestions for hardware
    Variable Bitrate therussman2002's Avatar
    Mar 2004
    Milwaukee, WI
    I am very, very tired of the three usb sound cards and 2 usb radio/tv units that i have been trying to get to work. So ive decided to screw my epia m10000, opus 90w, and 160gb 3.5" hd onto the back of my sub box. Once i buy a dual pci riser card dealy, i plan on getting a pci sound card, and a pci tv/radio card. I am wondering everyones opinions on the best options for those 2 pieces of hardware. I usually have bad luck with creative, but if they sound the best and have the best software features, fine
    Also, my trunk gets super super hot as it is, i have 3 amps sitting behind that sub box and i cant touch them I plan on putting a couple of 80mm red led fans (with these sweet grilles that look like speaker grilles) through the rear deck next to my 6x9's for some exhaust but i dont think thats going to cut it. Anyone have any clever cooling solutions? (98 grand prix gt)
    AtDhVaAnNkCsE
    Jun 2004
    Dude, if your amps are too hot for touch, then you have other issues you need to address before moving your computer to the boot.
    In my tenure with car stereos I've found that if you can not hold your hand on the amp for more than 7 seconds without pulling it back due to pain then you are in trouble, they should not be that hot, even if the source of the heat is external... and it is isn't it? The amps are hot because your trunk is acting as an oven? If that's not the case then please check your setup.
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    Yeah that does seem kind of hot, I can drive with the music turned up for 6 or so hours and still put my hand on the amps.
    Mar 2004
    Milwaukee, WI
    i think the trunk is indeed like an oven at this point... 2000 watts rms of ampage gets things pretty steamy in there, was just asking if anyone had thought of some clever avenue of exhaust from the trunk of yer average car
    Jun 2004
    2000RMS still shouldn't be causing that much heat.
    Please check into it.
    As for your question about exhausting ones boot, I really can't come up with any cleaver ideas other than dropping the seats and rolling down the windows to circulate air. Your 80mm fans might work, but keep in mind the effects of positive/negative pressure and how that might affect the "junk in the trunk". I think you'll probably want to go with positive pressure in the boot, just running the idea thru my noggin makes me think it would probably be the best bet.
    Ever think about running some sort of duct from your AC unit into the boot and attaching an 80mm fan to the end of it to help pull the cold air in? Using that in combination with your 80mm exhaust fans might be a plausable idea.
    Maximum Bitrate owenjh's Avatar
    Nov 2003
    NC
    take a look at WizardPC's cooling system. Link is in his SIG... I think his solution would be the best if you want extreme cooling. Note: not the AC vent duct the other one.
    CarComputer Status: New Car & Broken (Motherboard Fried)
    Owen JH | My Linux Blog | The Tech Fellows
