quick lcd question! anyone whos done one knows the answer!
do i connect the ground to a black wire on the power supply or to an actual grounding like the car chassis?
i would say either will work fine. you can directly connect ground to chasis or ground to pcps
your chasis should be at the same potential (theoreticaly) as the black wire, but use the black wire.
http://mp3gt.mp3car.com/
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
