Oh, forgot to mention that this setup will be used in the trunk of my car, and in AZ the trunk gets pretty hot. Will this be a problem for anything as long as I use smartfans(temprature sensitive)? Also I need someway to shut it down when the car is turned off, although if there isn't a cheap and easy solution I can always just hit the power button before the car is turned off.
LinkBack URL
About LinkBacks
