The ground loop isolator normally installs on the positve wire of the head unit, the device then has another wire which is to be grounded,
----ground---
++++GLI<
++++head unit+++
hopefully that helps.
Ok, i know that buzzing noise from inverter problems are the most talked about problems on here, but my question is how exactly does a ground loop isolator install? does it install in the cig lighter, does it install on the battery, does it install on the sound car feed, what? I havent gone to radio shack and looked yet because I have a busy schedule, but wanted to know before I went down there. In my system, the buzz isnt bad, can only hear it when I have my music up loud enough and theres a pause in the music so its something I can live with for a lil while, but probably wanna get it fixed before too long. Any info you can give me would be great.
Grand Am-P3
The Grand aMP3 Project
Car: 96 Pontiac Grand Am
Current Setup: AMD K62 300MHz, 64MB DIMM RAM, 20GB WD Hard Drive, Basic Video & Sound
----ground---
++++GLI<
++++head unit+++
mp3wrangler>
So does the Ground Loop Isolator plug in like a 1/8" stereo plug or what?
Grand Am-P3
A ground loop isolator is a transformer that decouples the audio signal from source and destination. It would be best to install the transformer end closest to the head unit or amplifier, as noise that is picked up between the output of the sound card and the input of the sound system would be removed. If the transformer is closer to the soundcard, noise can be picked up between it and the audio system, and amplified. The Radio Shack model comes with a 1/8" to dual RCA adapter.
http://avgeek.mp3car.com
KG6OQD
www.americansandassociation.org
so basically ill have to get this device that converts 1/8 to RCA and then get another that converts from RCA female to 1/8 stereo? the reason being for now im using a tape adaptor because i have stock stereo and dont want to change over
Thanks,
Grand Am-P3
Actually, you'll just need to get one 1/8" to RCA adapter to convert back to your tape adapter.
KG6OQD
