Results 11 to 20 of 21
Thread: No one uses the EPIA-TC1000 or TC600, why?
  1. #11
    Jul 2004
    Central NY
    What cases?
    Quote Originally Posted by Mick
    What are the advantages of using the carnetix power supply over just a sequencer/regulator like the ITPS? All the cases that I have seen already have a 12v DC-DC power supply, so I am just a bit confused I guess.
    First off I'm a bit confused what cases you're talking about, if you could specify I may be able to answer you. As far as the difference between the Carentix and the ITPS I've read on these forums that the ITPS won't survive engine crank. Anyway though, I'm not an expert on these two products but go to carnetix website and they have some articles on it and things that are linked to these forums so you can safely assume they're not [too] biased. Anyway hope this answers you a little.
  2. #12
    Jun 2004
    Sydney, Australia
    I'm pretty sure the Motherboard still needs 12v and will reboot if its not there. Basically the Carnetix regulator accepts from 8-20V where the ITPS only copes with 11-18 or something like that. If you have no need to survive cranking then i guess the ITPS would suffice...
    As for the cases, i assume you are talking about the Morex cases etc. They all have Morex 60W PSUs in them, so you'd throw them out if you were using the Epia TC motherboards...
  3. #13
    Variable Bitrate Pabs's Avatar
    May 2004
    Somewhere in the UK
    The ITPS will not survive cranking, and your PC will therefore reboot/shutdown everytime you start/stop the engine.
    Also, and larger spikes from the battery will damage the board. It needs a constant, steady 12v.
    If you want it in-car, Carnetix or Opus only.
    Do a search on these forums. LOADS of info.
  4. #14
    Newbie tankslappa's Avatar
    May 2004
    Essex, UK
    Quote Originally Posted by acura cl
    hey pabs... i'm having a problem with mine rebooting like crazy.
    i have a 3.5" 160 gig hard drive on mine and its regulated with an ITPS.
    other people on the forum said it was the hard drive making it reboot.
    are you having this problem?
    thanks.
    I have the TC10000, and was using the ITPS until recently. Basically the ITPS is crap. It puts such an insertion drop on the power I couldn't run the pc without the engine running. Even then the motherboard was only receiving 11.5v even though 13.8v was going into the ITPS. I've just received and installed the carnetix CNX-P1260, and it's an absolute joy! Even the cranking of my diesel doesn't bother it.
    Tankslappa
    Misubishi Shogun GLS 2.5 Turbo Diesel
    VIA EPIA TC10000
    80gig WD
    Carnetix CNX-P1260
    CarTFT/Lilliput 7" TFT - Touchscreen USB
    MediaCar 1.91b
  5. #15
    May 2004
    Essex, UK
    The motherboard itself is NOT a 12v component, it uses only 5v and 3.3v. 12 volts is only supplied for external 3.5" components such as a floppy, Hd, CD. etc. So, if I use 5v laptop drives, a constant 12 volt source does not seem to be an issue (correct me here if I am wrong).
    In theory yes, but from my own tests on the TC10000, if you drop below 11.3v input, it starts playing up.
    Voltage spikes on a 12v vehicle system are also something I consider to be extremelly rare if not close to non-existant. Case in point is that you already have a computer on board that controls the engine and it would be rendered inoperable if a "substantial' voltage spike were to occur.
    Not so much spikes, as ripples. That's why people get whistles and whines from cheap car amplifiers which pick these up on the DC lines. Having said that I got so fed up with my ITPS failing to support my TC10000 I just bypassed and ran it from the native car 12v, only effect I saw was a slight rippling effect on the Lilliput.
    Tankslappa
    VIA EPIA TC10000
    80gig WD
    Carnetix CNX-P1260
    MediaCar 1.91b
  6. #16
    Dec 2004
    QLD, Australia
    I am looking closely at a TC600 WINXPe. Finding it hard to justify the price though. :-/
    Rode-B[O]X: scrounging components
    Bits I bought:
    Xenarc 700TSV | DSSC | GPS18PC
    Pieces Im looking at:
    Axus TC600 WINXPe | EPIA * | GPS gadgets
  7. #17
    Nov 2003
    Marietta, GA
    Trillion,
    I believe what tankslappa was referring to was the TC6000 (not Asus TC600 WinXP system). The TC6000 motherboard has a +12V input with onboard DC-DC ATX PSU. The CarNetix regulator is a good match for these mobos with on-board DC-DC. It's a very cost effective solution.
    However, the ASUS TC600 also requires a +12V input. The CNX-P1260 is a good fit for this system. The P1260 includes a startup/shutdown controller so you won't need to spend the extra $ on a stand alone SSC.
    Hope this helps!
    MikeH
  8. #18
    Jan 2002
    New Orleans, La. U.S.A.
    This what I've found....... http://www.logicsupply.com/product_i...roducts_id/174
    the spec on the TC10000.
    But I have a question what mades this one http://www.logicsupply.com/product_i...roducts_id/211 different beside the price???
    Nimrod
    2001 Chevrolet Cavalier Coupe
    Nothing installed yet!!! :D
    J-BODY
  9. #19
    Mar 2004
    Maryland/NOVA
    the second one comes with a compact flash reader and pcmcia attachment.
    edit: if anyone is interested in a tc10000 i'll be selling mine soon because i have the nano-itx now.
    i'll have a huge f/s thread soon of all the extra carputer stuff i ended up not using.
    2001 Acura CL traded for a 2006 Subaru Legacy GT
    7" Lilliput Touchscreen
    NANO-ITX+m1-atx
    512 DDRsodimm
    60g SATA Laptop HD
    4x Apple DVDslot
    digimoto OBDii
    mS GPS
    mini BT keyboard
    relocated HU faceplate
  10. #20
    Jan 2002
    Thank you for the reply... Keep me posted on your leftovers LOL
    Nimrod
    J-BODY
  1. Mounting EPIA
    By phc in forum General Hardware Discussion
    Last Post: 05-21-2004, 09:54 AM
  2. VIA EPIA Motherboards - Which one is this???
    By pyros in forum General Hardware Discussion
    Last Post: 03-12-2004, 12:15 PM
  3. Original Epia VS Epia M
    By MeanGT in forum General Hardware Discussion
    Last Post: 09-23-2003, 04:25 PM
  4. EPIA M9000 & TM701 Problem
    By PTCruiser in forum LCD/Display
    Last Post: 03-28-2003, 02:43 PM
  5. Epia M and Epia 800 differences
    By wysiwyg in forum General Hardware Discussion
    Last Post: 12-20-2002, 11:50 PM
