Results 1 to 10 of 14
Thread: Long IDE cables
    Mar 2001
    Regina, SK. Canada
    Post Long IDE cables
    I need some help with an issue here. My computer box is in the trunk of the car but the CD drive is going to be in the dash (where the stereo used to be). Now the problem is, how do I connect the two parts together? I'd need about a 6 foot IDE cable to reach it and the longest I could find was a 4 foot on Ebay. What kind of options do I have? Are Female-Female IDE connectors available to hook up two 3 foot cable together?
    I've heard stuff about data loss over a long distance like that, is this because of the thin wire used in IDE cables? If so, what about chopping the connectors off a cable and soldering 14 gauge wire in it's place? Is the wire inside an IDE cable plain copper wire, or is it some special kind?
    So many questions! I'm really close to getting the system operational, just have to work out a few of these kinks now.
    AMD Duron 750, 128m RAM, 10gig WD, 12.1" TFT screen, SB Live! 5.1, custom plexiglass case
    TalonTemple.com
    TalonTemple.com
    Newbie JrFaust's Avatar
    Jun 2000
    Eagan, MN
    Post
    Well, you'll most likely have to make one. I made a 10 ft. cable out of cat 5 network cable, works great.
    Good luck,
    JrFaust
    That's right, you just got passed by a computerized toaster...
    Mar 2001
    West Yorkshire, United Kingdom
    Thumbs up
    cat 5 works, sweet as
    another option is usb?
    John McLear - [email protected]
    http://www.205oc.co.uk
    UK Mp3car slapnut
    #mp3car - Efnet
    Carplayer and Mediaengine *****
    spank gemma.co.uk for holding my motherboard for so long. still no board, wood work nearly done :|
    [-----------(90%)----] Completed :)
    pics at: http://www.zcentric.com/~mitcht/gall...me=Convertable
    Retired Admin Aaron Cake's Avatar
    Jan 2000
    London, Ontario, Canada
    Cool
    This has been covered countless times before. Use the "search" feature to look for "IDE cable".
    Aaron Cake
    Player: Cyrix 200, 32MB RAM, 10.2Gig Quantum HD, Onboard EtherNet/Sound/Video, Custom Lexan Case, Arise DC-DC, Win95 Kernal w/Custom Player
    Car: '86 Mazda RX-7 w/Basic Performance Upgrades
    Mar 2001
    Regina, SK. Canada
    Post
    Well I searched the archives for stuff about long IDE cables and really came out empty handed. Lots of people have asked the question, but few have gotten a real answer. It all just ends up talking about theories and then just ends. The only one with a real answer was one where it said you have to use USB or really complicated signal booster. Well that doesn't really help much.
    Jr, how'd you make the cable out of Cat5? Isn't an IDE cable 40pin and a networking cable I would guess would be much less than that? Thanks for the help!
    TalonTemple.com
    TalonTemple.com
    Jun 2000
    Grand Rapids, MI
    Post
    You're correct, there are a lot of threads about long IDE cables that were never responded to, but IIRC there was a long thread devoted to the topic a few months ago.
    Cat5 cables have 8 wires. You have to have 5 cables running together.
    Jun 2000
    Eagan, MN
    Talking
    Correct cat 5 has 8 wires (4 pairs twisted) so I took 5 runs at 10 ft. each then I took apart an IDE cable and used the ends. I didn't use any crimping tools nor did I solder the connections I just pushed down each wire in to each connection (you'll see what I mean if you take an IDE end apart). Note this took some time and swearing so set aside 2-3 hours.
    Hope this helps and may the force be with you
    JrFaust
    Mar 2001
    Regina, SK. Canada
    Post
    Ah ha! Did some playing around with the word choices for the search and finally found the right one.
    http://www.mp3car.com/ubb/Forum2/HTML/001501.html
    Went to Ebay and found a 50 foot roll of Cat5 for $10 so I'm on my way!
    TalonTemple.com
    TalonTemple.com
    Maximum Bitrate gizmomkr's Avatar
    Dec 2000
    Smyrna, Ga, USA
    Post
    Just wondering if annyone with extended IDE cables has tried playing DvD ?
    Gizmo-
    Techonlogy on Wheels
    http://www.hjnetworks.com/car
    Maximum Bitrate Meatballman's Avatar
    Jul 1999
    Hartsville, SC
    Post
    gizmonkr: Read the thread linked to directly above your post
