Results 1 to 5 of 5
Thread: What is the max temperature rating for the C3 cpu?
    Variable Bitrate The Grinch's Avatar
    Jun 2004
    Toronto, Canada
    I'm still building my carputer and I've got my MII-10K mounted where I want. The enclosure is a little restrictive right now and airflow could be a bit better. Today I had the computer running for about 30 minutes and I decided to jump to the bios to check out the CPU temp. It read 60C! That is what I would normally call a touch on the very hot side, but then again every manufacturer has different heat tolerances.
    What's the max CPU temp for the C3?
    Carputer progress meter: [-----|]
    Carputer gadget meter: [--|---]
    Maximum Bitrate bertybassett's Avatar
    Sep 2003
    Gloucester (UK)
    yeah I'd like to know this one for my M1000
    Jul 2004
    Central NY
    Look at the PDF quasi-buried on VIA's page
    Buried on VIA's site is a PDF about the C3 Nehemiah core processor's specifications. Here's the link: http://www.via.com.tw/en/Products/C3...3_Nehemiah.zip On page 69 of the PDF section 6-1 there's thermal characteristics. It says between 0 degrees celsius (32 degrees F) and 70 degrees C (70*(9/5)+32 = 158 degrees F) is it's operating range (noting 85 degrees C for the EBGA version). There's really not too much else in that section but this manual is quite useful and full of specific information on the processor! take a look!
    Maximum Bitrate Seth's Avatar
    Jun 2004
    Athens Greece
    I think the max temp for the Nehemiah core is 85ºC . Can't remember where I read that though.....
    EDIT: Ooops *alias beat me....
    Jul 2004
    Central NY
    Well at least I served to refresh your memory as to the source of the data.
  1. CPU Voltage & Temperature
    By mmendis in forum Software & Software Development
    Last Post: 02-05-2004, 11:51 AM
  2. CPU & Case Temperature
    By Sway in forum General MP3Car Discussion
    Last Post: 02-03-2004, 03:25 PM
  3. VIA c3 800mhz cpu
    By mprover in forum General Hardware Discussion
    Last Post: 06-24-2002, 02:21 PM
  4. $200 DC-DC ATX PSU + CASE + MOBO + C3 800mhz CPU
    By moahdib in forum Power Supplies
    Last Post: 05-20-2002, 09:50 AM
  5. max cpu speed in a book pc model #bki810
    By Ces///M3 in forum General Hardware Discussion
    Last Post: 01-27-2002, 03:41 AM
