Results 1 to 9 of 9
Thread: Available DAB receivers for PC
    Raw Wave
    Jun 2003
    http://www.radioandtelly.co.uk/dabreceivers.html#pccard
    Will be trying one out soon and hopefuly its good enough to get rid of the HU
    Raw Wave Confused's Avatar
    Aug 2003
    Essex, England
    I've got a Wavefinder sitting at home waiting for me to finish coding AIMEE, and put it back in the car.
    So far, AIMEE is the only software that will give you decent control of a DAB radio, of those listed on that page.
    The quality of DAB radio isn't brilliant, as the BBC have crammed too many stations on each multiplex, and therefore have sacrificed the quality of each station. Most stations are 128kbps MP2, and sound worse than a good FM signal.
    Garry
    Co-Developer of A.I.M.E.E
    www.aimee.cc
    Maximum Bitrate riddle14's Avatar
    Aug 2003
    TN
    what is DAB? it looks like its UK specific?
    "I'm going back to Cali(Iraq), Cali(Iraq), Cali(Iraq), I'm going back to Cali(Iraq), Cali(Iraq), Cali(Iraq), I know so!!!!" Now I'm here!!
    By "ToneRiddle"
    Aug 2003
    Essex, England
    DAB is Digital Radio, only it's not particularly good.
    The technology is capable of 256kbps MP2 per station, which isn't too bad quality, however as I said, the BBC has put more stations on each multiplex, and therefore the quality of the stations has come down, so it is anywhere between 64 and 128 for most stations, and a couple are at 160, and a couple at 192.
    DAB is UK/Europe specific, but the US has a much better alternative, which is XM.
    Garry
    www.aimee.cc
    Aug 2003
    TN
    ah i see, thanx
    By "ToneRiddle"
    Raw Wave
    Jun 2003
    Thanks for the info...hmm kinda dissapointing then
    I didnt know much about it but the way they described the technology as if its a million times better than a normal radio. I hope new station appears with a much higher bit rates, forget the BBC
    Aug 2003
    Essex, England
    Quote Originally Posted by Ricky327
    Yeah, it was being touted as better than sliced bread, and it's still being promoted.
    Unfortunately the BBC basically "own" DAB radio, and therefore, it's up to them who gets what, and they have so many stations on there, that anyone else wanting to go on DAB has to share with everyone else, so unless loads of the stations decide to not go on DAB any longer, then no one will get any more bandwidth to themselves.
    I really want a technology like XM to be brought over to this country, however as the BBC has invested so much money in DAB, they're not going to give that up and move onto a better medium such as XM
    Garry
    www.aimee.cc
    Newbie SlashEMc2k's Avatar
    Dec 2004
    UK
    I have a Sony XAV-7W this support XM only prob is I`m stuck in the UK any one know any convertors so I can convert DAB to XM
    Just a question if anyone knows..
    Evo
    Evo is offline
    Low Bitrate Evo's Avatar
    May 2005
    UK
    Thumbs up Working USB DAB Radio for sub 100
    Well after blowing up one Wavefinder and having the other blow itself up I finally gave up on them.
    I have found an alternative USB DAB radio called the Trinloc MP3 Recorder for just 99.
    I have one now and can report good sound qaulity and software and drivers that work on XP SP2 Couple this radio with a Blaupunkt Autofun DAB car aerial with amplifier and thats a working mobile DAB solution.
    Also remember to get the SMA to BNC converter to make connecting the Blaupunkt aerial easier, however you will need to fit the BNC connector supplied with the converter to the aerials coxial. (Not difficult)
    Aerial and DAB radio available from the following links:
    Trinloc USB DAB Radio
    Blaupunky Car Aerial with amplifier
    SMA to BNC Converter (See bottom of page)
    Now I just need some plugins to get it working with the best Carputer front ends. Apparently DABBar will support the Trinloc next release.
    Hope this helps some of the other Brits on the forum.
    Life moves fast, so don't get left behind, buy a fast car!
  1. FEELER: Internal IR receivers for use with remotes
    By chiefsalami in forum Classified Archive
    Last Post: 07-18-2004, 02:42 AM
  2. usb dab receiver
    By Hitman in forum General Hardware Discussion
    Last Post: 07-08-2004, 05:40 PM
  3. DAB Wavefinder
    By Andrew Taylor in forum General Hardware Discussion
    Last Post: 03-07-2004, 12:32 PM
  4. DAB radio? PSION wavefinder
    By craigyb in forum Software & Software Development
    Last Post: 09-22-2003, 09:10 AM
  5. Are USB GPS"mouse" receivers good?
    By felix99 in forum GPS
    Last Post: 09-30-2002, 10:14 AM
