Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: carputer hard drive died in 3 days
  1. #11
    Newbie f150tech's Avatar
    CT
    Compactflash or IDE Flash Module with Windows XP Embedded and Enhanced Write Filter On(Read Only) 4 teh win!
    1GB IDE Flash Module for about $150
    http://www.transcendusa.com/DLCenter...22&Contain=ALL
  2. #12
    Maximum Bitrate fluffy2097's Avatar
    Jul 2003
    Fremont, CA
    Quote Originally Posted by f150tech
    Only $150 more and you could get a 20GB Ipod for your music. CF is not terribly cost effective.
    A digital mind lost in an analog world.
    Learn to ask smart questions!
    http://www.catb.org/~esr/faqs/smart-questions.html
    My car PC: The Lost Cause!
  3. #13
    Jul 2003
    Fremont, CA
    Quote Originally Posted by therussman2002
    ____________________
    *|___________________|
    The stars indicate the position of my late hard drive on the left side of the sub box. Imagine two rockford p3's positioned symmetrically on the front of that box there, if you will. The carputer is mounted on the same side of the box, just on the back. The thing was pretty secure using 4 lil "L" brackets. When i get the new drive from warranty this week hopefully, im going to put it in the same spot, and screw some fans around it. And like i said try out a slab of dynamat maybe. So if it dies again i quit (with the whole hard drive thing anyway, carputers 4-ever!!)
    P.S. for a few weeks my hard drive was loose on a piece of foam up by the dash when i had the carputer mounted up there. More random variables.
    EDIT: well you get the gist of the drawing, apparently when it posts it removes all seemingly unnecesary spaces
    Your problem is vibration. Don't mount your HD on your sub box. mount it somewhere there will be less vibration.
  4. #14
    Maximum Bitrate owenjh's Avatar
    Nov 2003
    NC
    I was going to mount a case inbetween a custom made sub box, guess thats not a good idea after hearing this. Have to rething my plan now.
    CarComputer Status: New Car & Broken (Motherboard Fried)
    Owen JH | My Linux Blog | The Tech Fellows
  5. #15
    CT
    Quote Originally Posted by fluffy2097
    I don't know what you are talking about.
    Only $150? That's only double the cost.
    Also, harddrives can't take punishment. How does an iPod solve that?
  6. #16
    Jun 2003
    Memphis - TN
    " it would be next to impossible to wipe out your hard drive with a magnet, it is quite easy to destroy a floppy disk (eek what are those) with a magnet"
    Its a myth a magnet will not destroy your data.
    Newest (August '04) Maximum PC has 11 common computing myths debunked. I have the mag.
    It explains that an unsheileded speaker is about 1000 Gauss, 10,000 gauss earth magnets stacked on top of each other would be incapable of corrupting data.
    2011 Nissan Frontier SL
    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
  7. #17
    Variable Bitrate The Grinch's Avatar
    Jun 2004
    Toronto, Canada
    I also agree with vibration. A hard drive is part mechanical and part electronic. If the vibrations don't hurt the mechanical parts first, it will eventually cause cold solder joints in the electronics. Get it off your sub and mount it somewhere else.
    Carputer progress meter: [-----|]
    Carputer gadget meter: [--|---]
  1. Cold hard drive fluid bearing data loss
    By Mikesz in forum General Hardware Discussion
    Last Post: 12-13-2003, 08:17 PM
  2. hard drive dissappears in windoze
    By bullzsht in forum General Hardware Discussion
    Last Post: 01-16-2003, 02:04 PM
  3. sonys hard drive car mp3 player
    By e36mp3 in forum General MP3Car Discussion
    Last Post: 05-30-2002, 12:54 PM
  4. Hard drive problems
    By UltraMan in forum General Hardware Discussion
    Last Post: 02-09-2002, 09:19 PM
  5. Idea to protect the hard drive...
    By Szech in forum General Hardware Discussion
    Last Post: 01-29-2001, 10:55 AM
