Results 11 to 20 of 27
Thread: Building a plexy case...
  1. #11
    May 2001
    Thessaloniki, Greece
    Post
    I'll go buy a hot knife tip for my soldering gun and give it a try.
    What about the PCI cards?
    I am thinking of mounting (on the exterior side of the case-parallel to the motherboard) a metal sheet corner on top of the slots I'll cut on plexiglass for the PCI card's I/Os- then screw the cards on that with self tapping screws.
    So each card will be supported by the actual PCI bus and a single screw... Do you think this will be strong enough for the car's environment.
  2. #12
    Jan 2002
    bit-tech.net
    Post
    I used the general purpose spiral cutting bit, #561.
    http://linear1.org/i/cutouts.jpg
    Then I used miniature filesto get the edges smooth and corners square.
    It's not shown in the pic, but I used fine snadpaper and Novus #2 polish to clean up those edges, and they have the *bling* now.
  3. #13
    moahdib's Avatar
    Jul 2000
    Post
    I built my plexicase with nothing but a scoring knife, a soldering iron, and this alcohol like glue u can buy at a glass or plexiglass shop for glueing parts together.
    04 Acura TL w/ core2duo 2ghz laptop w/ 1gb RAM on a docking station.
    Fast car, fast PC. ;)
    http://www.arcdesigns.net/carpc/
    My TL CarPC ver2
    FSR Flash Skin w/ moving weather maps
  4. #14
    May 2001
    Post
    No offence Moahdib but your case is not exactly what I have in mind.
    I don't want it to be glued together (by the way... this alcohol like glue is nothing but chloroform - used in anaesthesia back in the old days - try not to inhale it's fumes, it might cause renal/hepatic toxicity (=insufficiency!)),but bolted so that I can work in it and modify it easier and you didn't even made any holes on the plexy! You used that predrilled metal plate from a metal case.
    [ 01-17-2002: Message edited by: Dimitris1976 ]
  5. #15
    Nov 2001
    England
    Post
    flipping heck, its enough to make a person use metal
    SensitivePsycho
  6. #16
    Mar 2001
    Cincinnati, OH USA
    Post
    Did you take a look at mine Dimitris? I went with the "tough and rugged" look, meaning I used screws and brackets. Sounds like what you have in mind.
    http://www.mp3car.com/usersites/Maveric/ M.A.V.I.C. System
    Asus MB, PII 266, 192 MB Ram, 6.8" LCD, 6 Disk CD-ROM, 21 Gig HD, All-in-Wonder Video w/ TV Tuner, Irman, Windows ME, Winamp, Cobra III -- All in a custom acrylic case.
    http://www.mp3car.com/usersites/listings/ MP3car Listings - Please add to it! :)
  7. #17
    May 2001
    Post
    Maveric,
    that's the kind of case I am trying to build. How did you mount the video card? I am trying to find a way to mount PCI cards securely.
    Dimitris
  8. #18
    Mar 2001
    Cincinnati, OH USA
    Post
    It is actually held in place by one screw in the top. I took off the cover-plate and then cut off the angle at the top where it would screw into your case. Then I drilled a hole in the top of the cover-plate where it was to be screwed to the acrylic case. It works like a charm.
  9. #19
    Feb 2000
    Rockford, IL (home), Southern IL (college)
    Post
    i mounted my PCI cards securely by flattening the metal on the end of the PCI card. Instead of a 90 degree angle, its all vertical. Then you just match up the card and drill the holes. Thats just one way on how to mount them.
    2004 F-150
    Shuttle XPC, 80gig HD, Wireless Internet, DVD
    "How piMP3d is your ride??"
  10. #20
    FLAC PatO's Avatar
    Dec 2000
    Afton MN
    Post
    Cooler way to mount cards:
    Remove the metal bracket off the card and drill holes for whatever sticks out - vga connecter, 1/8" stereo plugs, network card, etc.
    It works really well for sound cards! Plus, you don't have to worry about lining up the motherboard a certain distance from the side of the case - all you have to do is but it up against the corner.
    I found drilling a few holes much easier than cutting long strips for the metal bracket...
    http://www.jeepmp3.com/
    CarPC Stolen. Starting over.
    Ne1 recognize the avatar?
