Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: Building a plexy case...
    May 2001
    Thessaloniki, Greece
    Post Building a plexy case...
    I find it very hard to cut some decent looking rectangular holes at the back of my plexy case for the various I/Os (parallel/serial/usb ports, ps/2, etc...).
    I make some small holes with a drill for a start at the corners and then I use a Dremel tool with a cutting wheel to connect them, but I already destroyed 2 sheets of plexiglass.
    Could you suggest a better/proven technique?
    Also, any ideas on how to mount the PCI cards?
    Dimitris
    FLAC LESLIEx317537's Avatar
    Jan 2002
    Long Island, NY
    Lightbulb
    I am about to make a Lexan case or Plexi glass case myself.
    I would think using a dremel with the correct wheel would be easy. Which cutting wheel are you using? I cut my metal case side with a fiber disc.
    SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
    GPSing - Digital Speedo
    Relocating headunit and extending faceplate
    Button app to Alt-Tab between two programs
    Mar 2001
    Cincinnati, OH USA
    Post
    Here is what I found works well.... Use a piece of sheet metal as a guide with a thin Dremel attachment such as the engraving tool. At high speeds the thin tool cuts through Plexi like butter because of the friction caused heat.
    http://www.mp3car.com/usersites/Maveric/ M.A.V.I.C. System
    Asus MB, PII 266, 192 MB Ram, 6.8" LCD, 6 Disk CD-ROM, 21 Gig HD, All-in-Wonder Video w/ TV Tuner, Irman, Windows ME, Winamp, Cobra III -- All in a custom acrylic case.
    http://www.mp3car.com/usersites/listings/ MP3car Listings - Please add to it! :)
    FLAC PatO's Avatar
    Dec 2000
    Afton MN
    Post
    Here ya go:
    http://www.dremel.com/productdisplay...1&Color=99CCFF
    Works like a dream! Used it on my harddrive mod. Even for large cuts where you can't use the arm, it's much easier to not have to hold the spinning, noisy dremel while making precise cuts. The dremel drill press looks cool, too. Haven't tried it, though.
    http://www.jeepmp3.com/
    CarPC Stolen. Starting over.
    Ne1 recognize the avatar?
    Apr 2001
    Portland OR
    Post
    Do you have access to a saber saw? I cut all the holes for my player by drilling holes and then using a saber saw to square the cuts.
    -Jeff
    MPEGBOX - Plexiglass Computer
    www.mpegbox.com
    Mar 2001
    Cincinnati, Ohio
    Post
    Get a laser pointer. Draw two dots where you want to cut between. Very quickly swing the pointer so the red dot goes back and forth between the two dots. This will make a very exact cut, but will take several Millinea
    Clarion 200watt head unit w/ Aux in.
    Kicker 800watt 4 channel amp
    In a 96 Grand Prix SE.
    Jun 2001
    Washington State
    Post
    Being that I don't own a dremel I used a soldering gun with a flat head attachment to cut through the plexi. It works like a knife through butter, if you can handle the fumes that is!
    Jul 2001
    Post
    you can always take it to a plastics company - they should cut all the holes out for you for about $50 and it will come out perfect
    Constant Bitrate SuperAJ's Avatar
    Aug 1999
    Talking
    I took my plexi to a glass/plastic shop, and the guy just ran a glass cutter over the cutting line like 30 times, then folded along the crease to break apart the plexi.
    It wouldn't work for small I/O slots though...that soldering attatchment sounds like a good idea, really smelly/messy though.
    PS: I tried taking a spin saw to the plexi. Even though i was going EXTRA slow once that blade hit the plexiglass it broke off a huge chunk and sent it 40 feet into the air.
    FLAC PatO's Avatar
    Dec 2000
    Afton MN
    Post
    Originally posted by SuperAJ:
    <STRONG>PS: I tried taking a spin saw to the plexi. Even though i was going EXTRA slow once that blade hit the plexiglass it broke off a huge chunk and sent it 40 feet into the air. </STRONG>
    Not that I've tried using a circular saw (or the like) to cut plexi, but I'd imagine you'd need a very fine-toothed blade. Something for masonry or finishing.
