Results 1 to 10 of 12
Thread: OPUS 150w Powersupply unit question.
    Newbie Jimbuh10's Avatar
    Jul 2004
    Los Angeles, California
    Okay, I got my comptuer setup up and everything, I need to get my power supply set up. Once I plug everything required from my power supply to my computer mother board, where in the car do I put the other end of the power supply to?
    Thanks. Okay. Bye.
    cheap custom title JC-S60's Avatar
    Mar 2004
    Ghent - Belgium
    The car battery... use a fuse!
    I don't know if the opus has a separate connection to the ignition for shutdown/startup, but that should all be in the manual, no?
    Jul 2004
    The car battery itself? You mean I actually have to pop my hood up and wire my power supply to the car battery itself?
    Thanks. Okay. Bye.
    Jul 2004
    West Midlands, UK
    Quote Originally Posted by Jimbuh10
    I've not sen an opus yet but I guess there's an ignition live, permanent live and ground.
    Ignition could be taken from the car stereo loom.
    Permanent - straight to the battery with a fuse near the battery end (prob within 30cm).
    Check the manual for opus!
    Mar 2004
    UK
    You wire it to the battery direct with a cable suitable for the power you will draw (this is described in the manual). You only need to wire the red cable to the positive side of the battery via a fuse. The ground cable connects to the car chasis again with a thick cable. The remaining wire connects to the car accessory cable (I took my feed from the head unit), this is the cable which is supplied with 12v only when the ignition is on. The accessory cable is used to tell the Opus when to power off, send to standby/hibernation and power up the computer.
    Jan 2003
    Ruston, LA
    For best practice, yes. What is the problem ? You don't think twice about
    shoving a computer in your car but you're worried about running a power
    wire to the battery ?
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    Quote Originally Posted by frodobaggins
    Don't worry about Frodo. He doesn't even have a PC in his car.
    Jul 2004
    Thanks. Okay. Bye.
    Jul 2004
    anyone know if the opus 150w psu comes with an AC adapter too?
    Thanks. Okay. Bye.
    Raw Wave Laidback's Avatar
    Oct 2003
    Madrid
    Then you could use an inverter, instead of wiring it to your battery!!
  1. Opus 150W Deep Discharge Question
    By *Tone* in forum Power Supplies
    Last Post: 09-12-2006, 09:47 AM
  2. opus powersupply question (newb)
    By crash893 in forum Power Supplies
    Last Post: 02-01-2005, 07:07 AM
  3. Opus 150w question??
    By Magsino in forum Power Supplies
    Last Post: 07-12-2004, 11:05 AM
  4. opus powersupply question (newb)
    Last Post: 01-06-2004, 04:36 PM
  5. OPUS 150W Question
    By belezeebub in forum Power Supplies
    Last Post: 12-23-2003, 03:56 PM
