Results 1 to 7 of 7
Thread: What motherboard?
    Aug 2004
    What motherboard?
    I am making a new carputer and I need your advice on the motherboard to get. Should i get some of the used ones like the M10000 on the classified sections? Should I just buy a ready-to-go complete system instead of starting from scratch. Also, I checked mini-itx.com and i found several motherboards. I have the needed money to get something good, so what do you recommend. Is the new MII12000 the best motherboard out there? If not let me know what will be the best thing I can get to begin. I want something fast and that wont give me problems. THank for all your help.
    C4M
    C4M is offline
    Maximum Bitrate C4M's Avatar
    Apr 2002
    Sydney, Australia
    Can I recommend the search button to you.
    These forums are an opportunity for us all to share our discoveries rather than simply tell you what you should buy. The fact that you've just joined and started posting (and double posting) questions like this one would indicate that you haven't spent the time to read up and evaluate the information that is already here.
    There is a Newbie forum that you may have missed. Use it! It's there for people like you!
    Other than that - welcome!
    C!
    http://carpc.riposte.net
    I reserve all rights in connection to each post I author, without exception.
    Nic
    Nic is offline
    FLAC Nic's Avatar
    Oct 2003
    Melbourne, Australia
    goddam newbies
    Signature: [==||========] 20% complete
    Aug 2004
    Sorry. I have read through this whole forum and I have been reading all sections before finally posting. I dont mean to get any of you upset. I was just needing some help. I dont mean to be a "godamn newbie", my apologies.
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    It's all depend on what you need/want to run. I am not sure abot a M10K, but I choose a Micro ATX with a Althon Mobole CPU Simply because I don't know what software I will be using in the future. As you may know, each year, new software coming out and they require more processing power.
    I have test a mATX with Althon XP-M 2500 with a HD, CDROM works fine with a 150W PSU.
    mATX Mobo with an Althon XP-M 2500 is in the same price range as VIa M10k.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Variable Bitrate NoPistonPC's Avatar
    Boston
    Quote Originally Posted by admiremp3
    The only thing you really need a fast motherboard for is DivX playback. If you are only playing back mp3s, DVDs and mpeg-2 videos, then an M10000 should be fine. If you want to play DivX files and you have the money, then get the MII12000 or even an EPIA-P4 (which will provide more power than you will ever need but is the same size as the M10000 boards). However, all these boards will give you problems with both sound (audio quality is poor) and video (mainly with getting native video modes to work).
    EDIT: I just saw MatrixPC's post. If you have the space, then I would follow his advice regarding the mobile athlon + mATX combo.
    1994 RX-7, EPIA P4-ITX w/ Celeron 2.4 Ghz, Arise PSU, Xenarc 700TSV (new model)
    Aug 2004
    Quote Originally Posted by NoPistonPC
    I dont have much space, but I think I can make some. Is the micro ATX bigger in dimensions than EPIA's and does it work the same or even better? I do have a couple DivX and some Mpeg-2's.One more thing, How bad of a sound will I get with these kind of boards, and whats the deal with the native video modes playback? Dont mean to ask much, but I really want quality in my video files. THanks a bunch
  1. FS: Casetronics C134 and EPIA M9000 Motherboard
    By jusatry in forum Classified Archive
    Last Post: 05-17-2004, 04:38 PM
  2. Motherboard Vibrating, will it be damaged??
    By syclone477 in forum Newbie
    Last Post: 05-01-2004, 11:28 PM
  3. WT: Celeron Setup for Slot A motherboard
    By EBoundEE in forum Classified Archive
    Last Post: 04-28-2004, 03:06 PM
  4. Wi-Fi Ehternet PCI Card - Is my motherboard PCI Local BUS 2.1 Compliant?
    By smoldyr in forum General Hardware Discussion
    Last Post: 11-14-2002, 07:56 PM
  5. getting an odd motherboard to power on
    By karmann in forum Power Supplies
    Last Post: 11-28-2001, 05:27 PM
