Results 1 to 3 of 3
Thread: Power Supply Electromagnet + hard drive = :X ?
    Variable Bitrate egeekial's Avatar
    May 2004
    When mounting stuff in my case, I realized that the hard drive and uncovered PSU are going to be right next to each other. Is it possible for the coils in the PSU to zap the hard drive?
    Newbie fearthepenguin's Avatar
    Mar 2004
    I wouldnt worry
    I wouldnt worry so much about magnetism messing with the drive. The short answer is that those coils are chokes and wont have enough juice flowing through them to create any sizeable field. What I would worry about is
    1. Heat. Those two devices right on top of each other are gonna generate some serious warmth. Make sure you have a fan blowing that heat away from there
    2. Shorts. Make REAL sure that your drive is mounted very solidly and isn't going to jiggle its way onto the coils, or any other part of the power supply.
    It gimme the jibblies
    Oct 2003
    A simple permanent magnet is not going to damage your hardrive. Inside the hardrive itself is a extremely powerful neodymium magnet sitting no more than a few cm from the platters.
    To even mess with the magnetic patterns on the platters would require a strong ALTERNATING magnetic field. Something like a TV tube degausser coil may do the trick, but your PSU definately will not do anything.
  1. power supply buzzing help thing i found... read if u have noise
    By TimW in forum General Hardware Discussion
    Last Post: 02-25-2012, 11:48 AM
  2. My low cost, easy to build power supply...
    By SkinnyBoy in forum Power Supplies
    Last Post: 09-27-2006, 06:10 PM
  3. ATX, ITX DC-DC Power Supply
    By Navigator_82 in forum Power Supplies
    Last Post: 03-14-2004, 10:26 AM
  4. All-electronic flash drive and solid state hard drive
    By Typhoon747 in forum General Hardware Discussion
    Last Post: 12-12-2003, 02:20 PM
  5. Testing a power supply to see if good or dead?
    By Squeezer in forum Power Supplies
    Last Post: 03-17-2002, 12:19 PM
