Results 1 to 10 of 16
Thread: Carputer wont boot up after unplugging HD
    Mar 2004
    Ontario Canada
    Guys I disconnected the HD to access some power pins, but I booted the carputer up be accident with it unplugged, now it wont boot. I cant remember the exact wording but it asks for me to insert a bootable media. You should be able to disconnect HD's without this happening right??
    Go figure, happens right when I get my WIFI attenna
    FLA gospeed.racer's Avatar
    Dec 2003
    Portland, OR
    If it was disconnected while off, and you fired up the computer with it unplugged, nothing bad will happen. Turn everything off and recheck your connections. Turn it on and it should be ok. If it is asking for boot disk or whatever that means it cant see your hard drive, you have a power or connection issue.
    2005 Ford Focus ST
    Mar 2004
    Ontario Canada
    I got power at the connector, everything is plugged in tight. I went under the BIOS settings and set the primary Master to my HD and it listed it, which was blank, and now when I boot its says cannot find operating system?? Could this a possible bad Mobo?? Im lost guys, any one??
    Maximum Bitrate dodgetimes2's Avatar
    MI
    I would try booting off a Windows/Dos/Linux floppy or CD and trying to access the drive to see if your filesystem is still intact. Possibly just your MBR (Master Boot Record) is messed up.
    1.6GHz HP e-PC, 768MB RAM, 120GB WD HDD, Slim DVD-ROM, Onboard sound & video, 7" Lilliput, USB GPS Mouse, Audiovox FM Modulator, Vector 400 Watt Power Inverter, Windows XP Pro SP2, iGuidance 2, 15" Samsung LCD for the rear *Carputer not installed*
    Mar 2004
    Ontario Canada
    Correction it actually says "error loading operating system". I tried with my winXP in but it didnt load. I guess I have to set it to boot first off the cdrom instead IDE1(where my HD is), right?? By the way thanks for the help.
    Jul 2004
    West Midlands, UK
    Quote Originally Posted by syclone477
    Are you doing a new install? If opsys was already installed then check the hard disk pins are in tact.
    Fresh install - Yes set in BIOS for CD-ROM to boot first.
    Mar 2004
    Ontario Canada
    Not a fresh install, just stopped working, I already took a quick look at the pins on the mobo and the HD, all look fine , but I will double check, maybe Ill try another IDE cable??
    Jul 2004
    West Midlands, UK
    Double check and they try the IDE cable.... I'd have thought it would be one of them if all was ok before.
    Mar 2004
    Ontario Canada
    Tried another IDE cable, samething. I cant boot from winxp cd, or off the HDD. I guess it is gonna be either the HDD or the MOBO, right??
    Jul 2004
    West Midlands, UK
    Yep I'd be inclined to think so...
  1. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 08:35 PM
  2. Need help with External USB Laptop HD
    By VWTronics in forum General Hardware Discussion
    Last Post: 05-26-2004, 12:58 PM
  3. boot problems
    By tracker92 in forum General Hardware Discussion
    Last Post: 05-20-2004, 03:21 PM
  4. FS Carputer EPIA-M 1ghz, 256 ddr ram, 120 gig HD
    By xtentialyst in forum Classified Archive
    Last Post: 05-12-2004, 01:13 PM
  5. Newbie asks ? Laptop based carputer vs desktop pc based carputer
    By SAScooby in forum General Hardware Discussion
    Last Post: 03-01-2004, 01:59 PM
