I have an old dell inspiron 7500. I know the docking station for it is exactly what you described -> you just slide in your laptop into the docking station and all the wires to your screen and usb and such come out of the docking station. So you could technically hardwire your docking station to your car, attach all the wires and just slide your laptop in and out. I'm sure that the newer dells probably have similar things, i'm not sure. Here is a pic of the docking station...
dockingstation
Your plan sounds doable, but you will run into powering on problems. It will be cumbersome to turn your laptop on and off from the trunk, and I doubt you will want to open your brand new laptop up and start soldering wires to make an external switch. But it has been talked about a lot on this forum, so it is doable.
LinkBack URL
About LinkBacks
once those are fixed, have to buy wire to run from the battery to the back. been running everything off a splitter on the cig lighter for the past 3 months to fully test the equipment.
