Results 1 to 2 of 2
Thread: power button
    Jul 2004
    power button
    Is there any way to make this happen:
    I want to have a carputer where it is possible to make it so that it doesnt turn on unless I press a power button on my dash. I want it to be able to turn on when i have the key in I or II position but also during crank etc. Ive built computers before. Basically I am asking if I can make a button that works the same as a PC's power switch is if it was plugged into an AC power source similar to a typical desktop. WHAT WILL I NEED AND WHERE CAN I GET IT? ANY info is GREATLY appreciated. THANKS!
    Variable Bitrate Fox_Mulder's Avatar
    Melbourne, Australia The Truth Is Out There
    How do you plan on powering your car pc (inverter, opus, etc)?
    [edit]
    I have made an educated guess that you are planning on wiring your car pc using an inverter (please correct me if i am wrong). So what you could do is replace/move the inverter switch up to the front or use a relay to trigger it.
    I have included some very basic schematics of how everything would be connected. Basically the carputer will only start when the key is in the ignition with the acc line is powered AND the switch you install is on.
    Also I believe you will have to short the contacts the "on" contacts on your motherboard and/or set your bios to "Boot After Power Failure". Or something like that some other member may be able to help with this bit.
    Also check the Schematics/Pin Outs/Diagrams Thread for some useful schematics!
    [/edit]
    Fox Mulder
    2001 Toyota Avalon Vxi
    Toshiba TE2000 Laptop 1Ghz BU-353 Black Xenarc 700TSV HD & Analogue TV FM DVD/CDRW Car2PC Adaptor
    2004 Toyota MR2
    Intel Dual Core 2.0Ghz 1Gb DDR2 160GB SATA2 M4ATX Lilliput 7" TS BU353 DiNovo Mini Car2PC ODBII
  1. Rewiring ATX power button
    By DCC in forum Power Supplies
    Last Post: 02-07-2008, 06:17 AM
  2. mobo does not support resume on power loss
    By ashbosh in forum General Hardware Discussion
    Last Post: 05-18-2004, 10:49 AM
  3. getting an odd motherboard to power on
    By karmann in forum Power Supplies
    Last Post: 11-28-2001, 06:27 PM
  4. Brief power loss between ACC and start
    By Destin in forum General Hardware Discussion
    Last Post: 01-26-2001, 11:12 PM
  5. HELP!! Power Supply wont supply power
    By Saab in forum General Hardware Discussion
    Last Post: 08-28-2000, 10:33 AM
