You might try to reset the bios.
Other than that I wouldn't know.
Greetz.
Just when everything was working so well. Started up computer this afternoon after it had been working fine all morning... power light came on, fans came on, monitor power LED came on, keyboard LED's flashed and harddrive LED came on for 5 seconds and sound of harddrive spinning up and then nothing!
Tried a bunch of times and double checked all connectors but it won't boot up. It just stops before anything even shows on the screen.![]()
Help! Any ideas what the problem is? Anyone?
Thanks.
Honda CRX. Custom enclosure.
Supermicro SED MB (Onboard sound and TV-out). Celeron 700. 64mb ram.
40 GB Seagate HDD on vented foam mount.
Keypower DC-DC KP-DX 250H ATX 250W.
Delvcam 5.6" TFT LCD Monitor.
Old headunit (ripped out tape mechanism added audio inputs on back).
X10 RF mouseremote.
"Wired Ride" web site
The Australia/New Zealand mp3car Portal. Join now!
Greetz.
Raas - The Netherlands
ME: VIA epia m10000, lilliput 7', opus 150w, 80gb<br>
GF: IBM Thinkpad 380, ext. 3.5 80gb, 40x4, PB-IR
try reseating your memory, processor and video card.
Do you hear your hard drive churning (i.e. reading) at all, or does it just spin? Unless it's reading something, chances are it's a power problem, and it's only spinning because power is going to it. I've run into all manner of weird problem with ACPI mobos (I'm assuming your board was made in the past four years or so). Even if the power is off, heck, even if the board is fried, things plugged into it will get power. I'm not sure of the specifics, but that's part of the ACPI spec -- as long as the PS is plugged in, there's power in the system.. ACPI boards have no real "off". My first recommendation would be to get ahold of another power supply and see if it gives you any different results. Otherwise, some mobos will get themselves in a funk sometimes (like my old Giga-byte board). Try holding down your power button for five or six seconds, and see if that does anything. Since you didn't even get any BIOS messages, I'm quite certain this is a power issue, but unfortunately, that's about the extent of my knowledge.
Do you get anything to display?? Or pulse beeps??
If not, wiggle your ram around and push it in real well. It may have gotten loose. No RAM or loose RAM will cause it to hang. This happens to me all the time. You may have somehow fried it too. Swap it out and try your different slots. My board only has 1 of 4 slots left working...so try them all (individually...if you have good ram in a bad slot - you wont boot even if you have good ram in a good spot too).
I'm a ghost...email me if you have any questions on my old setup
My way outdated website: http://www.poboytech.net
FYI: I sold my 96 4Runner and bought a 1985
Wiggle all your cards, RAM and CPU. They can easily vibrate loose (you did glue them in when you assembled, right?). If that doesn't work, reset your CMOS. Also, make sure to check your IDE and floppy cables.
For newbies.... Hot glue NOT Super glue!!!!Originally posted by Aaron Cake:
<STRONG>(you did glue them in when you assembled, right?</STRONG>
http://www.mp3car.com/usersites/Maveric/ M.A.V.I.C. System
Asus MB, PII 266, 192 MB Ram, 6.8" LCD, 6 Disk CD-ROM, 21 Gig HD, All-in-Wonder Video w/ TV Tuner, Irman, Windows ME, Winamp, Cobra III -- All in a custom acrylic case.
http://www.mp3car.com/usersites/listings/ MP3car Listings - Please add to it! :)
He He, I had the same problem with a P100 mobo, never got it working, its DEAD!! could be anything.. :P had the same symptoms (HD led on for 5seconds, keyboard leds flashing) couln not get it to work, tried everything.. could have been becasue the first ram slot was faulty, but I never checked it.. I binned the board a few days ago, I think.. Well, sorry if this is wrong, or dashed your hopes...
Wow! Thanks for the support guys
While checking all the things suggested I moved the ram to the 2nd ram slot and the pc booted fine!
I used a very fine paintbrush and vacuum cleaner to clean the dust from the 1st ram slot, put ram back in it and now it too works fine
Thanks again everyone for the help... I am soooo happy... I now have music again!![]()
X10 RF mouseremote.
Cool, glad to hear you got it working.
