I dont know much about the quality of this but check this out
http://www.trianglecables.com/75-foo...ono-cable.html
I'm wiring my living room with some RCA cabling (I think). I am going to be running about 50 feet of right channel, 50 feet of left, and 50 feet of Video. And this is basically for my PS2 so I can just put it under the couch. (rather than having it dragged accross the room) After doing some searching I found THIS site that talks about making RCA cabling from CAT5. I wanted to know your opinions?
If this is a horrible idea, what are some other options?
thanks!
BossTone74
:My Car and Regular Computer:
http://home.comcast.net/~krypt2nite
our church uses like a 100 foot video RCA cable, so I don't think that'll be a problem. As far as audio goes... cat 5 would probably work, it's been done. From what I understand, which is contrary to the myth, it's not sheilded in anyway, so you might run into issues, but other people say it sounds just as good, if not better. I say, what the heck, cat 5 isn't that expensive anymore.
My Carputer! (More Car Pics at the end)
2 Kicker Comp 10"
Epia M-9000, 256 MB DDR, 120 Gig HD
Lilliput 7" VGA Touchscreen
Check it out?!
I think you can buy that length. I am sure I have purchased 30 foot RCAs
TruckinMP3
Read the FAQ!
Take a look at the gauge wires in RCAs compared to CAT5. The thinner the wire, the less signal you will be able to push through it.
Here's my first link from a Google search for "50 foot RCA" and I came up with this: http://www.trianglecables.com/50footrcadua.html.
You can find 2RCA, 3RCA, 5RCA (component), 2RCA with S-Video. Look for something that is Male-to-Female so you won't need any couplers.
Derek
Progress [||-------]
View my Worklog to see some of my progress.
Downgraded Progress - Starting with another car... 09/13/06
did the shorter lenth of cable about 30ft. imo dont use cat 5. goto home dopot gat a roll of three wire lamp cord. use two leads for your rca and the third put an eyelet on and ground the eyelet to the chassie of your imput device ( tuner,amp,ect)
NOT THE PC.
keep all audio cables at least 8 inches apart and 12 inches for the video.
if you can try to use optical for your audio
also at those lenthes you may also need a distrubition amp, get a adjustable with discret chanels, so you dont over drive the video when try to get audio level proper.
y not jst buy rca wire in a roll? then put some connecters on each end........
search. there was a very very long discussion about the use of cat5 cables for audio.
I wouldn't do it. Others have done it and think its fine.
car computer rev 5: 8" lilliput and usual suspects
If anyone is interested...this is what I did with about 60 feet of CAT5, I got left and right audio and 1 video line from it and it looks and sounds great! (through my PS2) Man SOCOM is SO GREAT!
http://www.s10forum.com/forum/showth...threadid=32896
BossTone74
