Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: I got problems...
    Maximum Bitrate cadence117's Avatar
    Feb 2004
    Charlotte, NC
    I got problems...
    Ok, So the usb connector on my gps mouse got bent at a 45 degree angle on accident. So I bent it back straight and popped open my trunk to plug it back in.
    My motherboard is not in a case, So I put my hand on the metal casing of the usb ports to give force as I plugged the usb connector back in (the carputer was on) and all of the sudden everything shuts off.
    So I power down and back up again, but it won't power up, The computer will try to start up (cpu fan/ computer fan will spin up) for a second, and then stop. Then start up for a second, then stop. Just pulsing like that.
    I havent had a chance to try a cmos or anthing on it yet, but was just wondering what yalls opinon would be on what my problem is? any ideas?
    mobo $130 ; 150wOpus-$200 ; 256mb pc2700 -$10 ; 120gb HDD 7200-$70 ; Lilliput TS 7"-$265 ; USB LAN-Free AR ; Rikaline 6010 GPS-$34 ; ShuttleXpress-$37
    Total = $746....Carputer = Priceless
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    sounds like a short. Unplug everything and replug. Try that
    Maximum Bitrate Yuriy's Avatar
    Jun 2004
    Seattle
    I shorted by USB ports before, nothing bad happened. I also don't think it could be static. Probably not receiving enough power.
    00 Saturn SL2, boosted @ 8 psi - CarDomain
    Newest install - my quickest ever
    My 2nd carputer - b4 I broke the touchscreen
    My very first carputer - voted the most ghetto
    Feb 2004
    Charlotte, NC
    Yeah i'm getting 3 flashes on my opus, which is also pulsing power every other second or so. So how do I fix it?
    I tried unpluging it all..and nothing
    Feb 2004
    Charlotte, NC
    Update,
    I took everything apart and stuck it back together,
    now it will start up but i get no visual display.
    Screen powers, Then just goes black.
    pip
    pip is offline
    Maximum Bitrate pip's Avatar
    Mar 2004
    Parker, CO
    1) reset your bios, sounds like your onboard VGA isn't healthy
    2) try a PCI VGA card
    3) replace your mobo, it may be fried.
    Jan 2004
    California
    No.... don't replace anything (yet)
    Make sure your memory is pushed in all of the way. Make sure all cables and connectors are properly snugged in.
    Let you computer rest overnight.
    You could pop in a PCI video card to see if you actually booting up into windows but you just cant see it...(bad video?)
    It is possible that your motherboard could be fried, I would take it out if its case and examine it closly to look for burnt componants or black marks.
    Ask in the power supply forum what the three pules means for the Opus, This may help diagnos the problem
    Good Luck
    Variable Bitrate lawrence's Avatar
    Oct 2003
    carol stream illinois
    i had a bad usb cable once. didnt know it untill michine wouldnt boot.
    the mb was only a month old so the company exchanged it for a new one.
    put it all back together and saw a spark when i pluged in the cable. and the cable got real hot like right now. unpluged it and swap cables and all was good. called the guy that sold the mb and cable ( thank god it was the same place and time for both).
    when he had sent out the mb for exchange thay said the voltage regulator was bad.
    he was glad to find out it was the cable becouse they would not exchange it and he would be out a mb. the mb was a gigabyte p4.
    Oct 2003
    it aslo flash the LED next to the power conector every 1/2 second and the fan powered off the mb just kind of twitched and would never spin.
    Feb 2004
    Charlotte, NC
    okay, Here's abit more detail, as my last post was rushed.
    The symptons are very similar to a previous problem,
    Fried mobo->ALIVE- Opus to blame,
    and the Fried MB thread on that forum.
    similiar as in:
    VGA goes blank,
    EVerything spins up,
    No "windows" noise (So I know it's not actually starting up all the way),
    Last time it just fixed itself when i hooked it up to a ac-dc powersupply and then back...
    I'll give that a try, but it's a bit concerning that the problem is repetitive...
    P.S. (The 3 flashes is gone, the problem has progressed to the Blank VGA/boot problem.
  1. Problems installing Girlfriend 1.0...
    By gospeed.racer in forum Off Topic
    Last Post: 10-18-2005, 06:17 PM
  2. Hard drive shock problems.
    By Mikesz in forum General Hardware Discussion
    Last Post: 03-21-2005, 04:37 PM
  3. Dell Inspiron 8200 & Lilliput TS problems?
    By bkpsu in forum LCD/Display
    Last Post: 08-15-2004, 02:55 PM
  4. Shutdown Problems - Troubleshooting Guide
    By brettwmd in forum Power Supplies
    Last Post: 05-28-2004, 12:46 PM
  5. Lilliput problems (yet some more)
    By samc in forum LCD/Display
    Last Post: 05-06-2004, 10:51 AM
