Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: getting Cable on TV-Tuner
  1. #11
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    Post
    Use a VNC App (best for me: PCanywhere) and just connect the cable to you tv tunner card (the one in you desktop) then remote access the desktop from the carpc.
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Quote Originally Posted by bgoodman
    We're an international forum, post in whatever langauge you like.
  2. #12
    Low Bitrate widower's Avatar
    Jun 2005
    You could also use orb to broadcast your tv shows over the net.
  3. #13
    FLAC john1701's Avatar
    Mar 2004
    Fort Myers, Fl
    Quote Originally Posted by Adam F
    There is no way to get cable tv from and antenna if that is what your asking.
    FALSE! NOT TRUE!
    At my girlfriends house she can get MTV2, speed channel, QVC, Fuse, CNN, with a regular tv antenna.
    CAR:2001 Ford Crown Victoria
    PC: Acer EEE 900HA with Win7 with CF 2.0.
    Memory:1G
    Drives:160gig
    WI-FI:Cingular
    GPS:IG2k9
    Screen:Xenarc 700TSV
    The Florida Meets Thread
  4. #14
    Jun 2005
    Michigan
    Quote Originally Posted by john1701
    FALSE! NOT TRUE!
    Unless someone is rebroadcasting a pirate signal in the area, those channels dont have broadcast license....
  5. #15
    Newbie Spyder1331's Avatar
    Aug 2005
    Your moms place
    Enter the...CAAAAAAABLE GUUUUY!
    Quote Originally Posted by rsd212
    Okay let me clear this WHOLE thing up, I was a linesman tech for AT&T Broadband and Comacast for three years. Not to come across as a dick, but most all of you are wrong to a degree. The channels that you do not subscribe to are scrambled, we all know what swiggle porn is. So this signal is descrambled in one of two ways so your TV can properly display a clear image. The first is a cable converter. We are all familiar with these, you either pay to rent one from the cable company(digital or analog) or you buy a black box and only descramble the analog channels(this can't do digital, binary code vs. wavelengths). The black box works by using a variable capacitor, so that it will adjust the incoming signal i.e. 603.9649412mHz (yes the frequencies are this specific!) to 603.9648407notice how close these are, as the output frequency that might match that of lets say channel 65 on the box. That frequency is then modulated into the frequency of channel 3. Basically what you're doing with any set top box is using it as the tuner, thus rendering the one built into your dormant (except for channel three if you are using the F-type connection. This is one way that it is made difficult, ever notice how you sometimes get it for a split second, thats because your acting as an antenna working with or against the signal. Other ways they will avoid unauthorized veiwing is by using "traps", these are nothing but filters that block out that extra noise on certian channel carriers. Other traps will be added to allow you to watch premium channels such as HBO without a converter, right Schuck ;-), and sometime both a converter and traps are needed, that is if you want VOD. So yes it is possible to get HBO, MTV2, etc on a TV w/o a converter. Depending on what system your cable company uses, IRC, HRC or STD you may use more of your TV, ever notice that when you program a TV that it usally goes up to 126 channels? Hacking a digital box is nearly impossible, some cracks have been done, on some brands of converters like SA's, but as a whole are very secure. And stealing from the Dish is wicked easy, a lot easier than not getting caught trying to hike a pole or busting open a pedestal/doghouse and getting a security sleve off and figuring out what line is yours!
  6. #16
    Unregistered User ODYSSEY's Avatar
    Feb 2001
    Raleigh, NC USA CarPC Ver3: [▓▒▒
    Think they are talking about over-the-air.
    ODYSSEY
    Quote Originally Posted by Tidder View Post
    Digital-Car UK|
    (\__/)
    (")_(")
  7. #17
    Mar 2004
    Fort Myers, Fl
    she does not have cable, no cable box, descrambler, dish, anything remotely used to get cable, legit or not. All she has is this:
    Radio Shack antenna
    however, it does depend on the time of day she can receive those channels. She can pick them up better at night.
    Memory:1G
    Drives:160gig
    WI-FI:Cingular
    GPS:IG2k9
