Check to see that the drives are properly configured as master/slave on both IDE channels.
Im currently installing drives / windows to my computer but i keep get ting I/O Disk erros when it trys to boot off the HDD. Also i am getting Secondary IDE Conflitcs. Any ideas ? =\ thanks
Check to make sure the drive is properly configured in the bios
well it shows the drive as proper size, make, model in the bios but when it gets past and i try to install win98 it just says i dont have a drive there at all..
have you FDISK'd it yet? You will need to format it and then create a primary dos partition for windows to see it.
Or rather the inverse of that..![]()
Make a partition, tag it active, then format..
I cheat, I own an empeg.
Meskimen's Law: There's never time to do it right, but there's always time to do it over.
http://civic.mp3car.com
I know...but when i run Fdisk it says there arent ANY drives...its not recognizing it once it gets past the BIOS
Was there anything on the HD before?
95 Honda Civic DX Coupe - In Progress
mp3civic site
