Results 1 to 6 of 6
Thread: Opus remote trigger. Amp turn on
    Mar 2004
    I there, i no dont have a head unit. My opus doesnt have a remote trigger as standard but ive found the point i need to solder onto, its just the delay is 42 seconds after the computer first gets power! Thats far too long. WHat are other options to turn on amp after a lesser time, say 10seconds.
    cheers
    Jamie
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    You can just use a 12V output from your Opus. If you need a delay, you can build a simple RC circuit, or use a simple 555 timer based circuit. Alternatively, you can hook your amp-turn on lead to your serial port through a simple switching transistor. This will allow you turn your amp on/off programmatically whenever you like.
    I believe this has been discussed several times before. Did you try the search button?
    Mar 2004
    yeah, found a few solutions. Id live a turn on delay unit but id have to get it from th US of A. cant find any in UK. Shame oopus ain t adjustable
    Raw Wave Confused's Avatar
    Aug 2003
    Essex, England
    Put a wire from the 12V connection on the 4 pin molex through a relay hooked up to the ignition to the remote turn on on the amp
    This will turn the amp on after the Opus has powered up, and when you turn off the ignition, it will turn the amp off. The other option (of hooking the 12V from the Opus direct to the amp) is that it will still "thud" when you shut down the PC, which the method above will avoid
    (See attached image)
    Garry
    Co-Developer of A.I.M.E.E
    www.aimee.cc
    Mar 2004
    COnfused = top man
    have a buscuit, or a beer on me Ill give that a go tomorrow. SO i shouldnt get any probs with the Amp/PC coming ON simultaneously?
    cheers
    Jamie
    Constant Bitrate KaiTech's Avatar
    Quote Originally Posted by live2themaxuk
    cheers
    Jamie
    You can also send it to Opus for a software change and just pay for the shipping...
    I'll spout simplistic opinions for hours on end.
    Ridicule anyone who disagrees with me,
    and generally foster divisiveness,
    cynicism and lower level of public dialog!
  1. Turn on Lilliput with OPUS?
    By MaddSkillz in forum LCD/Display
    Last Post: 02-09-2009, 03:47 PM
  2. Amp Remote Turn-on via PSU?
    By bulgogi777 in forum Car Audio
    Last Post: 08-24-2004, 10:58 PM
  3. FS: Opus 90watt with Remote Trigger
    By naevity in forum Classified Archive
    Last Post: 03-29-2004, 04:47 PM
  4. remote turn on lead from headunit to power up PC
    By BluCivic93 in forum General Hardware Discussion
    Last Post: 07-27-2000, 02:13 PM
  5. amp turn on
    By jasmar in forum General Hardware Discussion
    Last Post: 07-21-2000, 08:51 AM
