Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Blue Screen O' Death. (MOBO Switch)
  1. #11
    Maximum Bitrate MoFo's Avatar
    May 2004
    TX
    yeah i had the same problem. Winxp will not let you switch mobos without reinstalling the operating system.
    You can try uninstalling all drivers for the motherboard and then switching.
  2. #12
    jol
    jol is offline
    FLAC jol's Avatar
    Jan 2002
    Mellansel, Sweden
    new mobo: REFORMAT/REINSTAL
    new hdd: REFORMAT/REINSTALL
    new keyboard: REFORMAT/REINSTALL(how often do you change keyboard anyway)
  3. #13
    pip
    pip is offline
    Maximum Bitrate pip's Avatar
    Mar 2004
    Parker, CO
    Quote Originally Posted by jol
    New keyboard? I don't even turn the PC off to switch keyboards...why on earth would one want to reinstall windows?
  4. #14
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    "Upgrade to Windows XP" works well too. It goes through the whole installing drivers, but also overwrites all the other files as well, while keeping all your settings and added software. Sometimes it can be a little better than repair. You lose all the updates either way, so you have to do that all over again. If you get SP2 before doing any updates, there will be a lot less updates to do. It has all the old updates in it and would be good to have on disk since it has the RDP patch so you don't get a virus as soon as you get online (unless you have a hardware firewall).
  5. #15
    Mar 2004
    Florence Yall, BFKY
    Quote Originally Posted by pip
    For example, if you install windows with a standard keyboard, then change to one with the media keys, it won't recognize those and there's no way to install a new keyboard driver. It's just stupid.
  6. #16
    Variable Bitrate RogerWilco's Avatar
    Aug 2004
    i say they should encorporate a small media card (that looks like a chipset) on your motherboard, so you could flash your drives via hardware rather than use microsoft to do it. It would be some much more conveint and there would be 1/100th the driver problems.
  1. Asus Micro Mobo and AMD XP-M 45W Barton
    By MatrixPC in forum General Hardware Discussion
    Last Post: 01-05-2005, 05:26 PM
  2. Mobo Woes - Enlightenment needed
    By nzKAOSnz in forum Off Topic
    Last Post: 05-17-2004, 08:24 PM
  3. Replies: 11
    Last Post: 11-29-2003, 12:36 AM
  4. Replies: 2
    Last Post: 04-28-2002, 10:59 PM
  5. ATX mobo users how did you hook up power on switch?
    By BeigeMaxima in forum General Hardware Discussion
    Last Post: 06-25-2001, 08:00 PM
