Results 1 to 9 of 9
Thread: Stupidme, USB 1.1 Micro Hub
    It's not really that small...No, seriously. judoGTI's Avatar
    Feb 2004
    So I got all giddy becasue I finally found a micro hub for 16 bucks, bought it , open it, see that it is a magical 1.1
    I don't have too much USB experience (takes me awhile to upgrade my home PCs ) Is this something that I should definitely go with a 2.0 Microhub?
    Or will I be OK if I use the 1.1? I know its slower, but I dont know by how much and I dont know if speed is the only downfall???
    I plan on using a USB 802.11g adapter, Touchscreen, GPS, and someday maybe a DVD drive.... ? Thoughts?
    '02 GTI
    [Routis '04] [Opus 90W] [160GB Maxtor HD]
    [Lilliput 7" TS] [VIA M10000] [XMPCR]
    [512MB RAM] [Custom housing]
    [Deluo GPS Mouse] [E-MU 0404 Soundcard]
    Progress Meter: [==============|] 99.9%
    Raw Wave kickercivic1's Avatar
    May 2003
    judo i can stupidme to my self also i just paid $11 or mine on ebay. and adobe is giving one out for free
    check it out now i am going to have two.
    FLAC chut's Avatar
    Jul 2003
    San Antonio, TX. USA
    you may find that the 1.1 hub wont work too well with a dvd player. I don't know what the transfer requirements are but I read on here that it won't work. Also,you may have to power a 2.0 hub to get the data transfer rate you want. For connecting appliances like a mouse or a powermate,1.1 is fine, for transfering large amounts of music, you may want the 2.0
    Stop Buying New Music CD's.
    Hit The RIAA where it lives.
    Indash Motorized 7", Epia Nehimiah, 512 MB, 80 GB, DVD, Wireless G, XP Pro, XM PCR, Kenwwod 5 Channel 1200 Watt Amp.
    Jul 2004
    Variable Bitrate RogerWilco's Avatar
    Aug 2004
    dont use 1.1 by all means it prolly wont even be able to read dvds in an external reader, you'll get away with the gps mouse (it'll have a slower refresh rate) and the 802.11g should be fine i believe its only 54 mbps. btw USB 2.0 Supports speeds up to 480mpbs, and since your new to USB dont run any cables longer than 16 feet, or suffer loss of data
    there is a reason Adobe gives it away free.
    Jun 2004
    Upstate New York
    I may be wrong on this but if memory serves me correctly, USB 1.1 is somewhere around 12Mbps. 802.11g is around 54Mbps so it doesn't make a whole lot of sense to me to use a USB 802.11g adapter on a USB 1.1 hub, might as well save yourself a couple of bucks and go 802.11b. If I'm wrong on the throughput speeds someone please correct me.
    Aug 2004
    why buy a 11b, instead of keepin the 11g and just getting a inexpensive small 2.0 hubs? tons of people have these things. They arent that expensive.
    Raw Wave Defiler's Avatar
    Jan 2002
    Temple Terrace, Fl.
    You can get a micro USB 2.0 Hub for $20 and a Sams Club or Costco.
    Aura MR62 (F and R)
    My Current MP3s
    Low Bitrate MikeXP's Avatar
    Aug 2004
    New Zealand
    USB2.0 hub is sure worth it, Also be sure to check if your system supports USB2.0 first!
    [ :: Digitize your in-car experience ]
    * what happened to my sig and avatar :confused: *
  1. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  2. Will this layout with a remote USB hub work?
    By NoPistonPC in forum General Hardware Discussion
    Last Post: 08-21-2005, 04:24 PM
  3. are usb 2.0 devices able to work with usb 1.1 hubs?
    By chris in nh in forum General Hardware Discussion
    Last Post: 06-28-2004, 08:27 PM
  4. Power for usb hub
    By bklynkaos in forum General Hardware Discussion
    Last Post: 01-24-2004, 06:45 PM
  5. wireless usb kb + mouse + hub idea
    By crippy in forum Input Devices
    Last Post: 10-12-2003, 07:06 PM
