Results 1 to 10 of 15
Thread: CF universal Boot Hardrives !!!
    Constant Bitrate chuckctv's Avatar
    Aug 2004
    Virginia
    This IC board makes a computer think a CF card is a master boot harddrive!!
    has anyone tried it, I would tink that windows would boot like lightning, and moving around in windows would be instatanius ((sorryspelling)). its on sell for 19.95, and I checked ebay you can get a 1gig cf card roughly 99$. If you install windows (even xp) on this but use a normal harddrive for storage I think this would be great not to mention the power saver here...
    Let me know what you think,
    http://www.mini-box.com/cfadapter.htm
    chuck
    Jun 2003
    Memphis - TN
    I have one.. my laptop harddrive boots faster.
    Plus CF cards have a read/write life.
    2011 Nissan Frontier SL
    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
    Jul 2004
    does everything run smoothly? how does it handle moving files around between folders etc?
    May 2004
    NJ
    like Custommx3 said, CF cards have limited write cycles, will go bad and corupt after about 5K to 10K writes. That is less than 2 month using XP, if OTOH you are using DOS or other OS, may be!
    Aug 2004
    Virginia
    glad to know
    Well if thats the case then I guess the best idea for a fast/power saver harddrive is the one everyone else has been saying -> 2.5"laptop hard drive.
    Im waiting for my touch screen to come in, and I've decided to search ebay for a high speed laptop with a broke LCD screen ,since im going to use external screen this is perfect - super savor low cost, complete computer package, 12 volt power safe, and a biult in battery for just in case everything goes wrong(battery dies, fuse problem,ect) when the laptop battery reaches 10-15% then it will self hibernate. Plus all devices can be purchased for usb (using a hub), also a lot of hot swappable laptops have an external cable that will hook up to a floppy/cd/dvdrom drive, which if extended could be connected to the dvd/rom drive and a laptop drive in a case could easily be mounted in a thin small cut out of the dash board, and its powered off the cable it self. this sounds like the most greatest idea i could possibly come up with.
    any downfalls to this idea- then please let me know....
    Chuck
    Maximum Bitrate Seth's Avatar
    Jun 2004
    Athens Greece
    There's another solution. The Creative Muvo2 hack.
    Check it out here : http://www.pcconsultant.com/microdrive.htm
    You'll end with a 4GB Hitachi microdrive for only a fraction of it's value and without worrying about write cycles.
    Variable Bitrate brooksware2000's Avatar
    May 2004
    Minot AFB, ND
    It's been beat to death in the forums but you could always make the CF drive read only and have the swap file onto another drive with your mp3's. I have a 1gig CF drive and tried to do this but could not get XP stripped down enough to fit on the CF card.
    Check out my hopefully useful site...
    www.hobbybotics.com
    It's still under design but it is functional
    Maximum Bitrate gork's Avatar
    Aug 2003
    Amarillo, TX
    One thing that has not been beat to death on the forums, though, that I feel is worth mentioning is that there are various types of flash that offer different performances relative to this discussion:
    There is NOR and NAND memories, and of both types you can build them as SLC or MLC. There are certain advantages to using either memory type or either technology depending on what you are doing (trying to get a lot of data into a small space vs read/write performance, vs longevity and reliability).
    The difference between SLC and MLC memories is a data density thing: SLC stores one bit (2 states) per cell and MLC stores 2 bits (4 states) per cell. MLC memories are the types referenced to have lifetimes of ~10,000 write cycles, but SLC memories almost always outlast 100,000 write cycles.
    NOR vs NAND memories are a little more complicated.. NOR memory provides higher read speeds than NAND, but NAND provides much higher write speeds.
    Finding out what types of memory are present in some no-name CompactFlash card you buy is likely going to be challenging, and what's more, some really nice CF cards have all kinds of crazy things they are doing these days (mixing NOR and NAND, adding RAM buffers, etc.) But in general, if you are developing an embedded device for read-only booting, you probably want SLC or MLC NOR memory due to the faster read speed and low rewrite need, but if you want high reliability over the long haul (ie for mp3 storage or similar; lots of updating), you want SLC NAND memory; no question. SLC NAND holds up well.
    MY CAR IS FOR SALE!
    See My Project Page for Details - 2003 BMW E46 ///M3
    Custom Dash Monitor Housing - OEM Fitment
    Custom Overhead DVD-ROM Housing in Headliner
    BMW I-Bus Integration
    My homepage with many other fun projects!
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    Quote Originally Posted by chuckctv
    Its easier... how do I know - cos thats what I did but they can be a bit slower than full size drives.
    Terran
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    Or you could just spend the money and buy an actual solid state hard drive like these, but they are quite expensive.
  1. CF Card for Windows XP OS boot???
    By englsh in forum General Hardware Discussion
    Last Post: 07-26-2004, 01:03 AM
  2. boot problems
    By tracker92 in forum General Hardware Discussion
    Last Post: 05-20-2004, 03:21 PM
  3. Anyone using CF card as boot devices
    By mpattonm in forum Software & Software Development
    Last Post: 04-10-2004, 05:10 AM
  4. Flash Memory Speeds? (CF & SD cards)
    By eCarô in forum Off Topic
    Last Post: 03-25-2004, 12:11 AM
  5. boot from CF?
    By etrik in forum General Hardware Discussion
    Last Post: 02-09-2002, 01:08 PM
