Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: RE-solder USB?
  1. #11
    Constant Bitrate JayKaye's Avatar
    Jan 2004
    Sydney, Australia
    just splice the wires inside the insulator on the cable and solder them directly onto the board if you like.
    Personally I wouldnt do that and id have some sort of plug there instead of a static connection. Even if you cant find a USB connector, just use any other sort of 5 pin connector (including the chasis for ground).
    Car PC v1 - 1999 - 2000
    DOS 6.22 - MPXF - 2x16 LCD - 6.4GB
    Car PC v2 - 2002 - 2006
    XP - 7" wide/touch - GPS - Tank batt relay - 100GB
    Car PC v3 - 2008
    XP - 7" wide/touch - GPS - 802.11g - FM/XM - OBDII - WWW
    [||||||||||||||----] 80% complete
  2. #12
    Maximum Bitrate cadence117's Avatar
    Feb 2004
    Charlotte, NC
    So your saying... cut my current cable.... solder on a new cable that has a new connector on it, and then plug in. Right?
    if so... How can I tell which wire is which?
    mobo $130 ; 150wOpus-$200 ; 256mb pc2700 -$10 ; 120gb HDD 7200-$70 ; Lilliput TS 7"-$265 ; USB LAN-Free AR ; Rikaline 6010 GPS-$34 ; ShuttleXpress-$37
    Total = $746....Carputer = Priceless
  3. #13
    Hayling Island, UK
    Colour code. there should be a red (+ve), black (-ve), green (data+), white (data-). and a braded sheeth (earthing).
    Just a question, how did you bend it?
  4. #14
    Feb 2004
    Charlotte, NC
    everything is mounted on a hinged board in my trunk. It was fine in the upright position, but when the board slipped down to the down position. there wasnt enough slack in the wires
  5. #15
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    They make connectors now! Here's Type-A if it's of any help.
  6. #16
    Feb 2004
    Charlotte, NC
    ok, So I opened it all up for soldering today... and I got problems
    as you can see, the Gray Usb Cable on the bottom (left to right) has, silver ground, grey, green, black, red... and the black USB CAble(the GPS) on top (left to right) has green, blue, yellow, red, black, white,
    http://community.webshots.com/photo/...80086518FlCyVR
    6 and 5 dont match...
    How should I solder these?
  7. #17
    Mar 2004
    Florence Yall, BFKY
    I'd suggest you get a DVM or just a continuity tester and check the old connector. If it uses the standard colors correctly, the pins shound be in the order of black, green, white, red if you're looking at the male connector with the pins on the bottom, but don't trust that. Make sure! So most likely if that's the order of the old one (black, green, white, red) and the new one is black, green, grey, red, then just connect it like that and chop the other 2 wires (blue and yellow) off and tape/heatshrink over them. I'd keep the wires short so there's not a whole lot of unshielded wire there too.
    EDIT: Oops, just noticed a mistake in the colors.
  8. #18
    Feb 2004
    Charlotte, NC
    so your saying the blue and yellow wires are worthless?
    I would do the continuity testing.......
    but unfortunately I already hacked about the old connector in a frustrated attempt to see where the wires led to which pins... I couldn't really tell, and now my connector is in shreds... Thanks for the suggestion though Curiosity, It definatley would have worked...
    Any other ideas?
  9. #19
    Mar 2004
    Florence Yall, BFKY
    Maybe someone with the same GPS would be nice and figure out which wires go where?
  1. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 08:35 PM
  2. Will this layout with a remote USB hub work?
    By NoPistonPC in forum General Hardware Discussion
    Last Post: 08-21-2005, 03:24 PM
  3. usb power problem: solved!
    By susman in forum General Hardware Discussion
    Last Post: 08-31-2004, 01:50 AM
  4. LILLIPUT Solder the USB cable etc..
    By darthvinh in forum LCD/Display
    Last Post: 06-17-2004, 04:48 PM
  5. Replies: 4
    Last Post: 04-06-2004, 09:52 AM
