Results 1 to 10 of 19
Thread: RE-solder USB?
    Maximum Bitrate cadence117's Avatar
    Feb 2004
    Charlotte, NC
    RE-solder USB? (Wire Alignment)
    My USB connector got bent at a 45 degree angle. Plugging that in fried my old mobo. So I need to repair the usb connector.
    Can I REpair the connection like this..?
    I need to get a usb extension cord.. like 3 ft or somthing. Take apart my current broken end connector and solder the 4 wires that come off the usb onto the usb extension cord that i will also take apart...
    Does that sound right,
    Am I risking frying more things??
    mobo $130 ; 150wOpus-$200 ; 256mb pc2700 -$10 ; 120gb HDD 7200-$70 ; Lilliput TS 7"-$265 ; USB LAN-Free AR ; Rikaline 6010 GPS-$34 ; ShuttleXpress-$37
    Total = $746....Carputer = Priceless
    Raw Wave Confused's Avatar
    Aug 2003
    Essex, England
    The cable on my usb-ide adapter got bent at 90 degrees, and now all 4 wires seem to be connected. I'm going to be doing this exact thing tomorrow, then I should have my DVD drive working again.
    Garry
    Co-Developer of A.I.M.E.E
    www.aimee.cc
    Feb 2004
    Charlotte, NC
    alright.. well get back to me on if it works or not, thanks
    Constant Bitrate GWRedDragon's Avatar
    Aug 2004
    Arlington, VA
    A lot of usb wires are small...I mean REALLY small. Soldering those things nicely is annoying...I'd suggest you use something anchored to the outer insulation to protect against accidental pulls, depending on the wire size they may break really easily.
    Feb 2004
    Charlotte, NC
    impatient cow:
    MOOOO
    FLA gospeed.racer's Avatar
    Dec 2003
    Portland, OR
    Yes, it will be very easy to fix, just 4 wires and if you know how to solder you should be set. Color codes are usually an industry standard. Make SURE to insulate ALL of the wires with good heat shrink. I would also reccomend coming out about a foot on the new section of cable, so your joints are not right at the usb plug. Keep it back a ways to prevent any bending problems.
    2005 Ford Focus ST
    Aug 2003
    Essex, England
    Well I didn't need to re-solder mine, none of the wires were bad
    But it's real simple to do
    Garry
    www.aimee.cc
    Constant Bitrate JayKaye's Avatar
    Jan 2004
    Sydney, Australia
    I think you will also need to solder the outside chasis of the USB plug to ground. Im pretty certain USB also uses that as a sort of '5th wire'.
    Have a look on the board where the plug was soldered on, if you see a track where the mounts are then you will need to do the above mentioned.
    Car PC v1 - 1999 - 2000
    DOS 6.22 - MPXF - 2x16 LCD - 6.4GB
    Car PC v2 - 2002 - 2006
    XP - 7" wide/touch - GPS - Tank batt relay - 100GB
    Car PC v3 - 2008
    XP - 7" wide/touch - GPS - 802.11g - FM/XM - OBDII - WWW
    [||||||||||||||----] 80% complete
    Feb 2004
    Charlotte, NC
    hmmm... okay, well as opposed to soldering, i was able to bend the pins back into shape... but my computer isn't recognizing it when i plug it in...
    Feb 2004
    Charlotte, NC
    ....is there anyway i might be able to solder on a new connector.... using only the wires coming from the cable...?
    I really don't want to buy a new GPS
  1. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 08:35 PM
  2. Will this layout with a remote USB hub work?
    By NoPistonPC in forum General Hardware Discussion
    Last Post: 08-21-2005, 03:24 PM
  3. usb power problem: solved!
    By susman in forum General Hardware Discussion
    Last Post: 08-31-2004, 01:50 AM
  4. LILLIPUT Solder the USB cable etc..
    By darthvinh in forum LCD/Display
    Last Post: 06-17-2004, 04:48 PM
  5. Replies: 4
    Last Post: 04-06-2004, 09:52 AM
