Results 1 to 8 of 8
Thread: which sound card to run 2 amps
    Aug 2004
    i have my sound system set up at the moment, but would like advice on which sound card to go for to split the signal to send one set to the sub amp and one set to another amp for my components, i was planning on just using a 3.5mm splitter but i thought that if i try and control the subs from the head unit i would add more bass to everything, so how to i wire it up properly?!
    cheers
    and befor any1 says i did but did not find anything relevant
    Maximum Bitrate DjBac's Avatar
    Jun 2004
    GREECE/Athens
    Most 5.1 soundcards do that!!!
    Or should I say all of them?
    Aug 2004
    so put a 5.1 sound card in, then use a 3.5mm cable to a rca lead end?and then use the sub/centre speaker slot for the sub?
    Jul 2004
    Get an audiocontrol three.1 line driver & equaliser. Just over $100 on Ebay for a used one. An *awesome* piece of audio equipment! Read up on it and you'll be convinced...
    Aug 2004
    i cant find any on a uk ebay mate
    Jun 2004
    GREECE/Athens
    Use front output for front speakers and center/sub for sub... You have to figure out the wires that are only for the sub ("left" or "right")...
    Aug 2004
    shall i use a spliter for them or get a cable thats already split, how will it know left from right?
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    just plug it in.. see which sounds best :-)
  1. Sound card / noise
    By Tha Hombre in forum General Hardware Discussion
    Last Post: 05-16-2004, 12:01 AM
  2. USB External Sound Card Recommendations Needed
    By prospero in forum Car Audio
    Last Post: 04-27-2004, 10:17 AM
  3. Quality of sound card.
    Last Post: 04-21-2004, 10:18 AM
  4. Inverter + hum + external sound card
    By lazarus in forum General Hardware Discussion
    Last Post: 02-18-2004, 04:02 AM
  5. Sound card and network card
    By Matthew_sl in forum Software & Software Development
    Last Post: 01-31-2001, 04:29 PM
