Results 1 to 10 of 11
Thread: melted fuses
    Oct 2002
    UK
    melted fuses
    Just had a look at my wiring and found the following (see pics).
    Anyone guess how this has happened then? Surely the fuse should blow if it was passing through to much current, these are 10amp fuses for my laptop dc-dc adapter.
    Theres nothing next to these fuses which I can see that would get this hot.
    Both fuses are still completely intact and working. Somert dodgy goin on.
    Volvo C70 - Installation in progress *gulp*
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Are they broke or melted.... hard to tell from the pic. They may have been installed poorly and have been broken by the ham fist useing pliers.
    TruckinMP3
    Read the FAQ!
    Variable Bitrate lawrence's Avatar
    Oct 2003
    carol stream illinois
    how hot is your power supply getting?
    Oct 2002
    UK
    they've melted... have been installed correctly and arn't really that close enough to the power supply.
    FLA gospeed.racer's Avatar
    Dec 2003
    Portland, OR
    Seen a few melted fuses in my day. Most of the time it is caused by a loose connection TO the fuse. Check your fuse holder or terminals depending on how you set it up. Probably a bit of a loose fit is all.
    2005 Ford Focus ST
    Stank Cheese n8scstm's Avatar
    Oct 2004
    Eastvale, Ca (Near Corona)
    Were they made in China? This is off topic, but when I bought my radio tuner, it came with a remote and batteries. The batteries were the cheapest pieces of **** ive ever seen. They looked just like Duracells but had Chinese writing on them. The outer surface was kinda lumpy so I squeezed the battery and realized that they were squishy like a marshmallow. I could have actually pinched the thing in half. Now we have an inside joke about them here at work.
    2.4 celeron
    150 watt OPUS
    micro atx
    xp pro
    tv/radio tuner card
    audigy
    Dual monitor Radeon
    802.11G Mimo
    xm pcr
    dvd
    gps
    8" Lilliput touch screen
    IGuidance
    dual optimas
    battery isolator
    15" screen
    My Truck
    Dec 2004
    Wichita Falls, Texas
    not trying to think your stupid or anything, but always gotta try every angle
    but does this fuse go in your hood/engine comparment? Make sure its not sitting next to something that gets really hot under the hood.
    Thats the only time I have seen a melted fuse in my life.
    Constant Bitrate HostileJava's Avatar
    Mar 2005
    Northampton, PA
    These fuses/holders are meant to withstand a pretty fair amount of heat. Unless you had it laying across the engine I doubt that enginebay heat cause it. I would think a more likey cause is what was suggested earlier. I loose fuse will somtimes arc in the holder and the loose connection will also cause resistance which will heat up the fuse. I've seen that occur quite a few times before.
    Oct 2002
    UK
    been quite a while from when it happened, i replaced the fuses and these ones haven't melted yet, still as they should be.
    They arn't in the engine bay, no where near any heat at all really. Must of been slightly loose like suggested, strange for both of them to go like that though.
    Constant Bitrate HoSS's Avatar
    Dec 2004
    Ok, they have obviously melted through heat.
    Theres 2 possiblitites here:
    1. A 10A fuse will not blow instantly at 10A or even 11 or 12. A fuse has a curve, ie 100A it will blow instantly, 15A maybe in 1 second.#
    But if you are running slightly too much current through, it may just get quite hot for a while before blowing. Use a slightly bigger fuse (assuming the wiring/load is rated for it)
    2. (most likely) You have a bad contact in the fuse holder, which will produce heat. Buy a better quality fuse holder.
    HoSS
  1. My linksys MELTED
    By beaverpants in forum General MP3Car Discussion
    Last Post: 08-06-2004, 11:58 AM
  2. Replies: 6
    Last Post: 07-14-2004, 08:07 PM
  3. Fuses - A good idea
    By gizmomkr in forum Off Topic
    Last Post: 02-06-2002, 02:05 PM
  4. still blowing fuses
    By ToxicPoison in forum General Hardware Discussion
    Last Post: 02-12-2001, 10:45 AM
  5. LCD 4x40 contact points melted away?
    By Lakers0340 in forum General Hardware Discussion
    Last Post: 04-22-2000, 12:48 AM
