Page 2 of 11 FirstFirst 1234567891011 LastLast
Results 11 to 20 of 107
Thread: BMW I-Bus How to connect..
  1. #11
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    NEWSFLASH
    I have found some other software to try.. I will let you know how this one goes..
    UPDATE..
    Well it works, but I think it would take alot of messing about to get it working right.. I'm happy at the mo using what I have..
    If anyone else whats a try its http://www.pcremotecontrol.com
    cheers
    CdR
  2. #12
    Maximum Bitrate wysocki's Avatar
    Mar 2004
    Los Angeles Area
    Outstanding sweetness, BUT!!! Does I-bus (or anything like it) work on a 2002 Mercedes C230k????
  3. #13
    Hey, I posted a bunch of stuff on I-Bus forums and here but nobody responded, will the i-bus work on my e36? I know I dont have the buttons but I dont really care about that, the main thing Id like to acomplish is intercepting messages from the obc or/and sending them. Ps How do you even hook up that controler? ;>
    Regards,
    Tom
  4. #14
    Jun 2004
    Hi everyone
    I too would like to know does the Rover 75 use the I-Bus system ? Its supposed to be the same as used on the BMW 3 series.
    My Rover 75 is a 2000 year build so i would assume its much like a similar year 3 series, it has the screen ( small version ) head unit. navigation drive as i have seen used in the 3 series.
    Also how would i connect the ibus controller/adaptor ?
    Thank you
  5. #15
    Nov 2004
    France
    Quote Originally Posted by CdRsKuLL
    All you need to do is add a few lines now to the .ini and your done :-)
    It makes the Carputer so much better to use to be honest.. full control of the volume is a must. I also mapped the up/down to curser up/down.. the RT key to 'enter' and the Phone button to the Esc key.. but you can map these to any buttons you want.. I'm using mediacar atm, but you can map it to anyone.
    I have attached the file.. let me know if anyone needs help
    hi,
    Yes i need Help !
    I understand how to get codes with the Ibus Interface but how can i map it to Mediacar ?
    could you post your modified file in mediacar as exemple ?
    FLAC Chairboy's Avatar
    Jan 2004
    Remember folks, if you run out of serial ports, you can get a USB->Serial adapter! They cost $20-$30 and add a serial port via a USB connector.
    Chrysler 300 - Fabricating
    http://hallert.net/
  7. #17
    Jul 2004
    I then needed to find the correct values for the rest of the steering wheel buttons.. these worked out as follows
    vol_up = 50046832111F
    vol_dn = 50046832101E
    phone_dn = 5004C83B8027
    RT = 5003C8019A
    How do you map those buttons to Frodoplayer? or any programs? I have my ibus connected and shows that its working button cant get the volume to change or mute
    can you post your .ini file? or give example how to map to different apps.
    Thank you
  8. #18
    Oct 2003
    Quote Originally Posted by bmwperson
    Regards,
    Tom
    Your e36 will have iBus if it is a 96 or after. Should be in the trunk where the CD changer is. I don't think it was used as extensively on our e36s as it was on the e46 and other newer models.
    MGR Boy - Can't tell you for certain, but I'd imagine you do have iBus in your Range Rover. Look it up on the internet and find out...
    Dan
  9. #19
    Jan 2005
    Where can I find documentation on where to find the wire(s) to tap onto my I-BUS PCB? I have a MY2004 325i
    // edit //
    Solution here:
    I-BUS found in HU
  10. #20
    Jun 2004
    AZ
    I got mine from the Cd changer harness. Nice little three prong connector that slips right onto the PCB from Resler. Here is a Pic on my thread....
    http://www.mp3car.com/vbulletin/show...966#post364966
  1. Solved: USB bus stays powered after shutdown
    By S4Per in forum Power Supplies
    Last Post: 05-28-2007, 10:09 PM
  2. 03 BMW 330i Dinan S3 Project
    By fattytl in forum Show off your project
    Last Post: 09-27-2005, 11:24 PM
  3. Replies: 1
    Last Post: 07-28-2004, 11:26 AM
  4. BMW pre-installed system - TFT ?
    By tsingsu in forum LCD/Display
    Last Post: 08-05-2002, 03:16 AM
  5. BMW TFT Sharp LQ065T9BR52 - how to connect?
    Last Post: 05-31-2002, 10:59 AM
