Page 3 of 11 FirstFirst 1234567891011 LastLast
Results 21 to 30 of 107
Thread: BMW I-Bus How to connect..
  1. #21
    Jun 2004
    Dan
    Sorry its not a Range Rover its a Rover 75, but as far as i am aware most of the electrical systems on the Rover 75 are the same as the 3 series BMW of the same sort of year.
    MGR Boy
  2. #22
    Jun 2004
    cdrskull i bow down to your l33tness
  3. #23
    Oct 2004
    St. Louis area
    CdRsKuLL: I loooooooooove your setup! you and a couple other BMW E46 carputers were my object of idle for many-a-months now. I just hope my carputer will turn out as good!
    Quote Originally Posted by Chairboy
    Remember folks, if you run out of serial ports, you can get a USB->Serial adapter! They cost $20-$30 and add a serial port via a USB connector.
    Seeing as my laptop doesn't have a serial port at all...I am also very very very interested to know if this would this work. But wouldn't you have to change the software to recognize the USB port as the "comm" port? (I don't know software...so HELP)!
    Toyota Tacoma Install
    BMW 325Ci Install - Old
    ZOTAC H55-ITX, Intel i3 & 320 Series SSD
    7" Lilliput 669GL, M4-ATX, SB X-Fi, XMPCR
    Win 7, RR, Garmin, DashCmd
    Morel Elate 9 3way & IDQ10 ported (active 4-way),
    JL Audio HD Amps, Audison BitOne.1
  4. #24
    FLAC Chairboy's Avatar
    Jan 2004
    No changes needed, windows sees it as a new comm port. Search eBay for usb serial and you'll find plenty of 'em for cheap, eg, around $10-15.
    Chrysler 300 - Fabricating
    http://hallert.net/
  5. #25
    Dec 2003
    France
    Hi,
    To download IBUSCOMM, go to the sourceforge web site :
    http://sourceforge.net/projects/beboxmp3/
  6. #26
    Feb 2005
    Excellent!
    Excellent work! I believe there are many people in search of what you have found!
    I am ordering Rolf's adapter today.
    Question: When I run the IBUSComm application I get an error message: "Componenet 'MSCOMM32.OCX' or one of its dependencies is not correctly registered: a file is missing or invalid"
    Any ideas? Maybe I need to have Bebox installed even though I won't be using it? (I want to control WinAmp and TheaterTek with this tool).
    Thanks,
    Paul
  7. #27
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    to solve this you have to register the file go to the command line (start, run) and type in
    regsvr c:\windows\system\mscomm32.ocx
    then the file will be in your registery, and the program can run
    of course the file must be installed it can be downloaded from http://www.martin2k.co.uk/vb6/vb6download.php
    unzip it to the \system directory
    have fun with it
  8. #28
    Feb 2005
    Thanks Enforcer!
    Now I just need Rolf's masterpiece
    Paul
  9. #29
    Jan 2005
    Ok so I can connect to the IBUS and receive signals.
    How do I send signals to the IBUS? I tried using IBUS Analyzer 1.0.0.11 and sending it through that. It's log says the message was sent correctly, but the HU doesn't react.
    For example, I tried to send "5004683B0106" (without quotes) which is steeringwheel up, but the HU doesn't respond with the right action.
  10. #30
    Oct 2004
    Madrid, Spain
    Has anyone tried it with RoadRunner? How could the settings be? I mean, I think RoadRunner doesnt' map keys, so I suppose I have to map WinAmp keys, am I right?
    I have just installed the iBus from Resler in my car, but I haven't got it running until I configure it. When I try to open the IBUSComm.exe, I don't see anything, any screen, any error message... is it normal?
  1. Solved: USB bus stays powered after shutdown
    By S4Per in forum Power Supplies
    Last Post: 05-28-2007, 10:09 PM
  2. 03 BMW 330i Dinan S3 Project
    By fattytl in forum Show off your project
    Last Post: 09-27-2005, 11:24 PM
  3. Replies: 1
    Last Post: 07-28-2004, 11:26 AM
  4. BMW pre-installed system - TFT ?
    By tsingsu in forum LCD/Display
    Last Post: 08-05-2002, 03:16 AM
  5. BMW TFT Sharp LQ065T9BR52 - how to connect?
    Last Post: 05-31-2002, 10:59 AM
