Page 4 of 11 FirstFirst 1234567891011 LastLast
Results 31 to 40 of 107
Thread: BMW I-Bus How to connect..
  1. #31
    Feb 2005
    After following Enforcer's instructions, IBUSCOMM.exe runs.
    When you do run it, you might think it has done nothing - but look down at your taskbar and it will be there, running minimized.
    Click it on your taskbar and you can see a log, simulate a IBUS message, exit the program, etc. Now I just need Rolf's connector (sent him paypal money but have not yet received a confirmation). Funny how some of us start with the hardware then search for the software and vice versa
    Anyone else with an e39 (especially M5 with the widescreen NAV) who can post their learning experiences? It would be very helpful to learn from others who have already mapped keys to various buttons. I'd like to take advantage of a bunch of the buttons from the radio/nav and maybe even map a command to "PAUSE" my player when the cell phone "MUTE" command is sent to the radio/CD.
    Come on with the stories please!
    Paul
  2. #32
  3. #33
    Oct 2004
    Madrid, Spain
    Quote Originally Posted by pkarmouche
    Paul
    Where are Enforcer's instructions?
    I have folloewd Cdrskull instructions, but when I run Ibuscomm.exe, it doesn't run minimized (it is not at the taskbar, but i think it is in the Task Manager, not sure).
    Balki.
  4. #34
  5. #35
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    If you asign Ibuscomm to a application, the application must be runnning before starting the ibuscomm app.. if its not, it will hang in the background until the application is started.. so if its in the taskmanager and not on your taskbar, then its waiting for the application its going to control to start, if the applictation is already started then you have got the window name wrong in the ini file.
    CdR
  6. #36
    Jan 2005
    Quote Originally Posted by phita23
    Ok so I can connect to the IBUS and receive signals.
    How do I send signals to the IBUS? I tried using IBUS Analyzer 1.0.0.11 and sending it through that. It's log says the message was sent correctly, but the HU doesn't react.
    For example, I tried to send "5004683B0106" (without quotes) which is steeringwheel up, but the HU doesn't respond with the right action.
    Does anyone know how to do this?
  7. #37
    Oct 2004
    Madrid, Spain
    ...and does anybody what do I have to write the .ini file for capturing WINAMP application?
    I mean, when Winamp plays a song, the title of the application includes this song, and it adds "Winamp" at the end (like "1. With or without you - Winamp")
    I have tried configuring ibus with "Winamp" "*Winamp" "<*Winamp*>" "<* Winamp *>" but the ibus doesn't capture the application.
    Please, I need a little help...
    Thanks.
  8. #38
    Jan 2005
  9. #39
    Dec 2003
    France
    Quote Originally Posted by Balki
    Thanks.
    Download the 1.0.20 version and read the IBuscomM.ini. You will see a new parameter AppClassSendEventTo you can use instead off AppCaptionSendEventTo. This makes IBuscomm to search the window on the class, not on the title.
    Example for WinAmp 2.81 :
    AppClassSendEventTo="Winamp v1.x"
    This will do exactly what you want.
    http://sourceforge.net/projects/beboxmp3
  10. #40
    Feb 2005
    ibus messages
    Thanks guys, I now have Rolf's gadget installed, IBus Comm software installed with WinAmp.
    Deep breath...
    It works! But I'm somthing is wrong. Please let me know what I need to do.
    1. Every 10 seconds or so this message pops up in Ibus Comm:
    Process Msg RAD_CDPOLL (Radio Polls CD)
    Reply was CD_POLLRESP (CD poll Resp)
    What does that mean? Is this normal IBus traffic?
    2. Most of the buttons I want to use do not generate any code or message in IBus Comm. The program responds to the steering wheel > and < buttons, as well as the 1-6 buttons and the NAVTKN button, etc.
    BUT - I want to assign kestrokes to the phone buttons on the steering wheel, and the clock and phone buttons on the stereo. Since the program doesn't respond to pushing these buttons does that mean I need to find out the codes for these buttons somewhere else and manually add them to the .ini file?
    3. Some of the commands work (using "simulate message" makes this testing easy). But many do not. Example: One of the pre-defined mapping sends a "keyboardmap" command of ALT-F4 - which as expected quits Winamp when I push "simulate message". BUT if I manually change one of the "keyboardmap" commands to, say ="f" it doesn't work (I have a GLOBAL HOTKEY setup so that pressing 'f' on the keyboard skips forward).
    Thanks again for your good work and willingness to help,
    Paul
  1. Solved: USB bus stays powered after shutdown
    By S4Per in forum Power Supplies
    Last Post: 05-28-2007, 09:09 PM
  2. 03 BMW 330i Dinan S3 Project
    By fattytl in forum Show off your project
    Last Post: 09-27-2005, 10:24 PM
  3. Replies: 1
    Last Post: 07-28-2004, 10:26 AM
  4. BMW pre-installed system - TFT ?
    By tsingsu in forum LCD/Display
    Last Post: 08-05-2002, 02:16 AM
  5. BMW TFT Sharp LQ065T9BR52 - how to connect?
    Last Post: 05-31-2002, 09:59 AM
