Page 6 of 11 FirstFirst 1234567891011 LastLast
Results 51 to 60 of 107
Thread: BMW I-Bus How to connect..
  1. #51
    Variable Bitrate Hark's Avatar
    Feb 2005
    Atlanta, GA USA
    Quote Originally Posted by ftouanen
    Download the 1.0.20 version and read the IBuscomM.ini. You will see a new parameter AppClassSendEventTo you can use instead off AppCaptionSendEventTo. This makes IBuscomm to search the window on the class, not on the title.
    Example for WinAmp 2.81 :
    AppClassSendEventTo="Winamp v1.x"
    Hi Ftouanen - any way to make the ibuscomm not a task on the taskbar, such that when you alt-tab it doesn't appear as one of the window choices? The GPS software I'm using (Copilot) doesn't embed very well in other front ends, and I'm using the "alt-tab" app to switch between music and GPS - but it also brings up the ibuscomm app, which is a pain. I still want it to be active, just not visible.
  2. #52
    May 2005
    IBUS Help needed
    Im just finishing up my carpc install in my e46 touring, and ive been trying to get my Ibus interface to work that i got from resler. Ive run and tested ibuscomm with cdrskulls settings for roadrunner and it interacts with rr, but when i press the steering wheel buttons nothing happens and there is no message in ibuscomm. Im thinking maybe i have the wrong kind of cable from the interface to my epia board. Im using a normal com extension.
    Do i need a crosswired cable or something? thanks for any help.
    Marcus
  3. #53
    Dec 2003
    France
    Quote Originally Posted by Hark
    It is already done !
    Have a look in IbusComm.ini
    [Settings]
    ; IBusComm can be totally invisible by setting Setvisible=False
    SetVisible=False <= will do what you want
  4. #54
    Feb 2005
    So ibuscomm is set up to route i-bus messages directly into one application.
    Is there any way to get ibuscomm to send the commands to windows for whatever application has focus?
    Thanks,
    Paul
  5. #55
    Constant Bitrate JPuma's Avatar
    Jul 2005
    NY
    yes, just rem out the AppClassSendEventTo="" line and it will work in whatever app is in focus, including your desktop.
  6. #56
    Feb 2005
    Atlanta, GA USA
    Quote Originally Posted by JPuma
    Sorry to revive this, but...
    I haven't been able to get IbusComm to control Centrafuse. I've tried setting the AppClassSendEvnetTo="centrafuse", and I've also tried to rem it out completely, but nothing seems to work. I can see the sw button presses actions occur, but it doesn't affect centrafuse. The CF hot keys are set to "CTRL-ALT-UP", for example, for the volume up keys (they are set like this by default in CF).
    I've got the IBuscomm.ini file actions set to "^%{UP}" for the volume up, with the rest set similar to this. Anybody have any ideas?
  7. #57
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    does CF accept any other sdk commands at all, you could adopt the source to suit your needs like I did for RR. If you can point me to some info I would be happy to help
    CdR
  8. #58
    Variable Bitrate vinzer's Avatar
    Jul 2005
    Montreal, Canada
    Does anyone tried all this with RR ? If yes than would you be pleased to post your ini files. Thank you
  9. #59
    Constant Bitrate Mattkins99's Avatar
    Mar 2005
    Seattle Area
    this app works with RR as is.
    Matt Atkins
    Seattle5s | President
    '01 M5 Lemans Blue/two tone black and silver interior
    Factory nav.... for now
    Old Car (almost sold)
    '98 540i-6 blk/blk
    Dell 300m | Xenarc 7" | Road Runner | iBusCOMM | NaviVoice | Streets & Trips GPS
  10. #60
    Jul 2005
    Montreal, Canada
    Thank you
  1. Solved: USB bus stays powered after shutdown
    By S4Per in forum Power Supplies
    Last Post: 05-28-2007, 09:09 PM
  2. 03 BMW 330i Dinan S3 Project
    By fattytl in forum Show off your project
    Last Post: 09-27-2005, 10:24 PM
  3. Replies: 1
    Last Post: 07-28-2004, 10:26 AM
  4. BMW pre-installed system - TFT ?
    By tsingsu in forum LCD/Display
    Last Post: 08-05-2002, 02:16 AM
  5. BMW TFT Sharp LQ065T9BR52 - how to connect?
    Last Post: 05-31-2002, 09:59 AM
